brake pressure senders fault
Mar 26, 2007
2,020
S.Wales
Do you have a problem with your pressure sensors?
Yes, getting an intermittent code from one of them G214, fault in circuit. It's only happened since I added a little box of tricks to fix my slow fan speed problem.
I don't think its possible that its that box causing the problem because it's only wired to the fan control module and then earthed to the car body.
The first time we put everything back together though we forgot to tighten the main earth lead completely :doh: and thats when I started getting lots of codes. Since then it's all been tightened up and I'm left with just the one fault.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Yup I'm getting the same, this for me has just been since brake fluid was changed. I have the nime box fitted for ages before this so don't think there were any links with this.
What else have you tried?
I've had mine MOT'd and nothing showed up during this to point toward any loss of brake performance.
Mar 26, 2007
2,020
S.Wales
Yes my brakes seem fine. On the weekend I am going to trace the wires from the sensors on the master brake cylinder and see where they earth. I earthed the nime box to one of the two screws under the battery, the smaller one nearer the wing (not the main battery earth).
I have a feeling that the brake pressure senders may earth to this, if not then I guess I will try replacing the sensor. A bit odd though as it only started after I fitted the nime box. It could be that the fault was a caused by driving with the main earth not done up correctly rather than the nime box itself.
It's a nightmare to find any info on the G214 sensor anywhere on the net.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
I've got a problem with both of my sensors at the same time, I'll have to check the earths when get home.
Have you traced these to the place under the battery or are you presuming that its there?
Mar 26, 2007
2,020
S.Wales
Presuming at the moment, the tracing will be done on saturday probably.
The thing is, when I ran the car with the main battery earth not properly screwed down I got a tonne of codes all relating to the ABS and intermittent circuit problems with other controllers (instruments, CAN gateway, etc.).
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Brake pressure sensors are both wired directly to the ABS controller, no earth connection. The master cylinder itself has a solid connection to the bodyshell, so there is no need for extra earth connections.
The ABS controller is earthed to the same point you have used for your add-on box. It's possible you have affected the ABS controller, which will mean a new unit. If you're lucky, you might get away with just changing the sensor.
Mar 26, 2007
2,020
S.Wales
I doubt it's a faulty unit due to the nature of the problem, its an intermittent error in circuit. Besides, why would the unit fail now? Seems far too coincidental.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Mines is intermitant aswell, only seems to happen when I'm driving the car not when wife driving.
I'll check my earth point as a starting point.
Mar 26, 2007
2,020
S.Wales
Junior, mine only seems to happen when I really use the revs, normally I drive quite sedately and didnt get any light driving over to my dads. Gave it some beans on the way back and the light came on. Perhaps it's a similar thing with you and the little lady?
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Aye very similar.
I'm also thinking that it might be when cornering hard aswell so hoping its this earth point as its well cheaper than new sensors
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Aye very similar.
Another thing to check....
My ABS would trigger at low speeds whilst turning e.g. pulling into a parking bay.
Basically the ABS wire was being stretched when I was turning the wheel and the cable had a small break just behind the sensor (front NS sensor). Only when I used a lot of lock and the wire got stretched did the broken wire send false signals and the ABS cut in.
A mechanic rewired the plug which cost me 30 mins of his time
Maybe of some use :shrug:
Mar 26, 2007
2,020
S.Wales
Checked my earths again today and everything looks fine. Discovered that my G201 sensor is now throwing a similar error to the G214 as well. It's starting to look like a fault ABS control module. Anyone any idea what thats likely to cost to fix?
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Not sur about this but cars are becoming more remove broken part and fit with new part orientated. Would doubt this is fixable but might be
Mar 26, 2007
2,020
S.Wales
Not sure what you mean Junior......fiddling about with the sensors on the brake master cylinder appears to be a b**tard of a job, almost impossible to get at and would require full system bleed, etc.
Had a good look around today and decided it's gonna have to go into the garage to do.
Mar 26, 2007
2,020
S.Wales
i'm saying I doubt that the sensors would be fixable, most of the parts are throw away and get new ones.
I see, quite right although you can clean them as that is often a reason why the sensors would throw errors.
Touch wood I have had no TCS light on my last four journeys, I'm sure its only a matter of time.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
I've been away for 2 weeks and the light didn't come on once with the wife???
very confusing.
I'm going to be getting into the guts of the car soon anyway so will have a look then
