Do you have a problem with your pressure sensors?
Yes, getting an intermittent code from one of them G214, fault in circuit. It's only happened since I added a little box of tricks to fix my slow fan speed problem.
I don't think its possible that its that box causing the problem because it's only wired to the fan control module and then earthed to the car body.
The first time we put everything back together though we forgot to tighten the main earth lead completely
and thats when I started getting lots of codes. Since then it's all been tightened up and I'm left with just the one fault.
