Digging up an old thread here - interested in changing out the DMF for SMF and also want a new clutch too.
Make & Model: Seat - Leon
Year Span: 2001 - 2004
Engine: 1.9L
Includes: ARL, ASZ eng
Performance Kit: SA872 - $619
Flywheel: SV81A - $479
Spec Aluminium SMF and Stage2 spec clutch kit. I am aware this is going to chatter, however i have a decent stereo and i'm sick of the DMF muddying the performance of the car. Do any of you guys know UK suppliers for this stuff or am i better off ordering direct from SPEC themselves?
I know the TT shop sale SPEC clutches at a good price if you want good back up but i found it a lot cheaper to get an American friend to buy straight from SPEC then post it to as a present. Why do you want an alloy flywheel other then Jason has got one?
Ever thought why you probably haven`t heard about any other diesel or petrol cars on this or probably any other forum using an alloy flywheel ? Alloy flywheels are weak due to the fact that alloy is weak. They are made by bolting a steel face on an alloy flywheel, the bolt holes take all the strain when you are engaging/disengaging the clutch and will brake the bolts or wear the holes making the plate loose. Alloy flywheels where made for motor sport use where every extra gram in weight counts plus the car would get stripped and checked regularly. Diesel only rev to 5K with max power about 3-4K it`s not like you are driving a V-Tec 12000 rpm engine with no power until 7-8k. If you want a very light flywheel just get the already lightened steel fly skimmed or drilled it doesn`t cost much.
