i reckon the owens turbo in both variants is on a par with the fp green and red,would you agree Bill? if that's the case then the latter would be the cheaper option.I can only see one rate to 400+bhp and the other 475+bhp.
I was looking at the 400+bhp one http://www.owendevelopments.co.uk/products/product-detail.asp?prodId=616
I assume this just bolts straight onto js manifold and downpipe for standard v34?
Would you recomend this route bill?
i thought this as well as my mate with a TT is thinking of going this route using the owens turbo+js mani etc.jabba told him it would be a straight fit but i don't agree like you Bill as the turbo is way too big to be underslung.except neither the red or green will fit on a JS mani.
Owens one needs some lugs removing off the head & block from what I saw of Dans A3 (RIP)
Mark Gunns who owns the corrado 4wd rocket ship has the owens turbo and it makes over 500bhp.
no but he's been in redline mag and golf+ this year,also his is a topmount set up. like Bill has said many times before top mount is the only way to go.Does he have a build thread or anything?
So just a few bits need taking off block for it too fit.
what about if you can only go under slung with the turbo due to space would this be any good as i have been intrested in this befor
are the owen turbos the same kind of spec as APS turbos ???
they do 3 different hp spec turbos too
a mate has the mid spec turbo fitted on a early S3 on a js manifold with 3 inch downpipe
= http://www.airpowersystems.com/wrx/aps_turbo.htm
he had to take a few alloys lugs of his gearbox but its all fitted ready for mapping
