G12MO X
84
Well my old backdraft kit is now removed and my new Jabba kit is being fitted
Here are the pictures of my new Owen/Garrett hybrid turbo, Hoping for 440+
Running 2 bar of boost, Work has started
All being done by Jabba as
said , will be ready for adi at combe on 11 oct all going well
Which turbo did you got for one rated to 400+bhp or the 475+bhp? Also did forge actuator come with or you buy that extra?
Went for the 475 one , the forge actuator came on it as standard , it also came already set up by Owens , looks the dogz ;)
4k.... would be amazing. not far off my tiny bt. this on a 1.9 20vt? backdraft modified engine?
be very interested to see the graph and hear how drivable the map is. i dare not ask the cost.
backdraft have not touched my engine , Vagtech rebuilt it and did a cracking job. Still 1.8 with rods , je pistons, valves and agu head
Phil, get some seimens 630cc items if you are wondering. Unless your ross inlet requires the shorter ones?
Have done loads already , engine rebuild big port and apr manafold done
Injectors and fuel pump done . Just kit, mapping and other little bits.
Will keep you posted
im just about to rebuilt my engine with pistons rods and valves just not sure on which kit to go for thats all
Im going to be watching with interest too, as im doing a similar build on ibiza. Are you going top mount manifold?
Not sure mate to be honest i suppose i will need the same size as the bosch ones, but i am thinking that 440's with 4 bar fpr will be enough for the 18G
