Went for the 475 one , the forge actuator came on it as standard , it also came already set up by Owens , looks the dogzWhich turbo did you got for one rated to 400+bhp or the 475+bhp? Also did forge actuator come with or you buy that extra?
when will the power come in? laggy?
good luck with it mate![]()
Have done loads already , engine rebuild big port and apr manafold donehow much fitted mate ?????
backdraft have not touched my engine , Vagtech rebuilt it and did a cracking job. Still 1.8 with rods , je pistons, valves and agu head4k.... would be amazing. not far off my tiny bt. this on a 1.9 20vt? backdraft modified engine?
be very interested to see the graph and hear how drivable the map is. i dare not ask the cost.
Do you know what injectors Jabba will be using?
Injectors and fuel pump done . Just kit, mapping and other little bits.
Will keep you posted
Went for the 475 one , the forge actuator came on it as standard , it also came already set up by Owens , looks the dogz![]()
Phil, get some seimens 630cc items if you are wondering. Unless your ross inlet requires the shorter ones?
Im going to be watching with interest too, as im doing a similar build on ibiza. Are you going top mount manifold?
