got delivered about an hour ago.
had a look over it. good brembos, 5 seatsport wheels. the 4 on the car are scuffed but 5th one is mint. got the wrong airbox on it and dv was loose. guessing he changed them for insurance. also got a upgraded lower tip pipe.
THEN!!!! i noticed it h as a full set of bilstein pss9 fully adjustable coiulovers....£1300 worth!!!!!
wot a deal. got pics will post later;)
only gutter is the dash airbag has gone off and the only good panel on the fron is the wing and headlight. nothing else i can use :(
had a real busy afternoon
got the front end off, not easy as it was all bend up. interior stripped inc dash. got most of the wiring loom off of the engine and interior.
stuck the seats in the vario also :)
pics when it was delivered
i have the sideskirt. it just popped off when it was coming off of the lorry
HoocH
its not been looked after great. never seen an engine bay soo dirty. paint is typical yellow....different shades.
the chassis leg is 's' shaped. what ever he hit, he aimed it well for the strongest part of the car lol. cant imagine if it didnt hit the leg:headhurt:
Im sure i recognise the reg no, this would be going back to it's original owner from new/near new
Another yellow one aswell, gotta be something to do with the drivers ;)
If you get stuck for a dash i do have a spare one but it's got holes cut in it where my cage goes through
good lad :D
also wanted to ask you if you changed the firewall in your ibiza to the mk3 one?
if not do you run hydralic clutch and how?
HoocH
just see in 1st page of your thread. you have a pic of holes for clutch master cylinder. you cut them? or as above, changed bulkhead?
I cut out the area on the firewall where the clutch and brake master cylinder were and then used it as a template to mark up and cut through my original one with a cone cutter
Was going to remove the 20vt firewall but the stuff they bond it in with is a pig so thought better of it
Hooch I am very interested in the brembos and the wheels. PM me a price asap and i will let you know as i get paid tomorrow!!!
