had a look over it. good brembos, 5 seatsport wheels. the 4 on the car are scuffed but 5th one is mint. got the wrong airbox on it and dv was loose. guessing he changed them for insurance. also got a upgraded lower tip pipe.
THEN!!!! i noticed it h as a full set of bilstein pss9 fully adjustable coiulovers....£1300 worth!!!!!
wot a deal. got pics will post later
only gutter is the dash airbag has gone off and the only good panel on the fron is the wing and headlight. nothing else i can use
I cut out the area on the firewall where the clutch and brake master cylinder were and then used it as a template to mark up and cut through my original one with a cone cutter
Was going to remove the 20vt firewall but the stuff they bond it in with is a pig so thought better of it
