Disabling Auto Locks & Selective Unlocking
CHR15B
2,567
9
Scotland
This comes up every now and then, here is the procedure to amend using VAG-COM.
To disable Auto Locks...
Turn on ignition, start up VAG-COM...
Go to "Select control module" from the main menu.
Select "46 - Central conv."
Click on "Adaption - 10"
Press "Up" next to channel number and watch for "Auto Lock" at the top.
When found Auto Lock, set "New Value" to '0' from '1' click "Test" then "Save"
Press "Up" next to channel number and watch for "Auto Unlock" at the top.
When found Auto Unlock, set "New Value" to '0' from '1' click "Test" then "Save"
Then click "Done, Go Back"
Remove key from ignition then the next time you start up those annoying locks won't bother you.
To disable Selective Unlocking...
Click on "Recode - 07"
The number in at present will be a even number, add one to that number to make it an odd number then click "Do It".
Remove keys from ignition and lock the car - the next time you go to unlock pressing the unlock button will unlock everything.
Owl
cheesy quaver
Aug 21, 2008
148
sheffield
whats the process of putting the auto lock on? just a reversal of the above?
selective locking??? never heard of this... what is it?
CHR15B
2,567
9
Scotland
Yip.
Selective locking is where the first click is drivers door, second click for other doors and boot.
Owl
cheesy quaver
Aug 21, 2008
148
sheffield
so look for auto lock, and change it to 1 from 0..
was told this came standard but mine hasnt got it on
Aug 20, 2005
529
stafford
I don`t mind the selective unlock or lock when you pull away. It`s the point when you stop the car and get out, go to the boot and its locked still [:@]
On my Leon as soon as you remove the ignition ALL the doors unlock :D
Owl
cheesy quaver
Aug 21, 2008
148
sheffield
got mine done saturday thank to a lad i know with vagcom.... but selective locking isnt an option on mine... well i couldn't find the option haha
txavi
HI, if you want to buy the Vag com you have different options. You can buy it in Ross-tech.com,
you can buy it in ebay with the drivers, but not with the software (you will have to "buy" it on the Internet,, the crack version).
In my opinion, is better in ross-tech.com (the original). If you are going to use a laptop with Vista you may have some problems ( between the version and the operative sytem) because with Win Xp is OK but with Vista...
I have a laptop with Vista and the version of the vag com is 311.2,and is perfectly working so If I can help you, let me know.
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
What drivers are you using mate as I cant get it working with vista?
dave.stretty
Hi Chaps,
I have a 2003 cordoba se tdi130pd (with performance torque - brilliant but eats clutches!) I am desperate to disable auto locking as it's driving me crackers (for 4 years!) and i didn't know it could disabled. Any how I'm in Chesterfield area, anyone out there with vagcom who could help would earn my eternal gratitude (body and soul if required). also got a permanent airbag light that needs sorting.
Cheers Dave e
txavi
drivers vista
hi Damoegan,
attached is the folder with the drivers (vista). If you have any problem you can use google and type " FTDI" one of the options is "drivers". and choose the option of vista.
<i'll try to give you a direct link to the website.
<ok...i don't know how to attach a document...can anyone tell me how to do it?
thanks
txavi
Damoegan,
I've got the version 311.2n (no problems to use with vista) / release 311.2n /vag com keygen , drivers and everything. But I don't know how to attach documents here...
tell me what you need.
Damoegan
Oct 15, 2007
8,993
Newcastle
Damoegan,
Could you email them to me please mate ;)
dErZ
203
Surrey
Lads im sitting in my car waiting to change the selective locking but there are 2 options to change
software coding 0-32767 00064
workshop code 0-99999 06402
do i put a 1 on both of them ??
