Horn goes off when i turn wheel
May 31, 2008
1,247
Hi guys, recently just fitted a new pedal box, put the steering wheel back on, started the car was fine. Turned the steering wheel and the horn just starts going crazy. I am wondering if it is a ground issue as i have chacked for bare wires and have not seen any.
Any help would be much appreciated.
Also there is a lead which i don't think was plugged in when i disassembled the steering column, don't know whether this needs to be plugged in?
May 31, 2008
1,247
I didnt take the stalks off lol, i might just plug that lead in and see what it does lol
CatB1
535
Manchester
www.freeserve.com
Hope its not a similar problem to my Arosa when the horn started going off with steering wheel movement.To cut a long story short,a wire in the wheel/column had chaffed, it caused the airbag to go off just as I turned the wheel to the left. Still got the scar's on my right arm. Be careful.
Pete
May 31, 2008
1,247
Wow that sounds pretty bad, so i guess its not a good idea driving it around like it is then. I have just disconnected the fuse for the horn. I have checked for wires that are chaffed and can't see any. Will have another look tomorrow though.
Also my airbag light wont go off. will i have to go to SEAT to get them to reset it or something?
GTV
Veggie powered TDi's
Feb 16, 2008
479
Cambridgeshire
yeah you will need to reset the fault codes for the airbag, I had to do this, as I refitted my steering wheel and drove it for a mile to make sure it was on streight before I refitted the airbag, once I did refit the bag the light would not go out.
May 31, 2008
1,247
Ok, what sort of money did this set you back?
Just worried about it going off in my face :S
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
sounds like a loose wire mate, i'd remove the airbag again and remove the black bits either side of the air bag and give everything a good looking over, then re-fit it all and hopefully you'll be sorted :)
May 31, 2008
1,247
All fixywixed just need guys from seat to reset the airbag now and then i can say job sort of well done :D
turned out to i didnt put the airbag wire casing back together properly lol.
p.s anyone know how much a dealer is gonna charge for an airbag reset?
1,247
I cant see why it would be expensive all they gotta do is hook it up to the pc and push 2 buttons :/
truCido
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
right that lead that you've got loose should be plugged in but I don't know what it does exactly, in your pic behind it you can see one plugged in already, if you remove it theres another slot behind it for another plug
