Boost Gauge / Silicone Hoses
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
How does one plumb a boost guage into a TDI if he no longer has the solid plastic OE boost hose?
Quite fancy a nice boost guage, but surely you can't plumb a 25PSI line into a silicone hose can you?
Is the only alternative the silver pankcake by the drivers wheel arch?
Bogwoppit
1,085
Lincs
If you are keeping the EGR mechanism you could always drill and tap that as its easier to get off the car than the inlet manifold.
tom167
bucksvag.net
Mar 27, 2006
201
Milton Keynes
Yes thats where i've drilled into mine.
But, if you're fitting nice silicon hoses you dont want an ugly egr valve in there :D lol
tom167
bucksvag.net
Mar 27, 2006
201
Milton Keynes
I'm currently not no, mines a normal egr with the internals removed, i've got a tap in mine for the meth injection. Can get you a pic if you want?
tom167
bucksvag.net
Mar 27, 2006
201
Milton Keynes
Novelty to be blatently obvious lol.
There was a kit going cheap and wanted to see if it would make the slightest bit of difference. It didn't lol. Maybe when its on higher boost with a bigger turbo i'll start to notice some gains, either way i suppose at least its in place now...
Aug 1, 2005
2,695
Cullompton . Devon
Bet it smells good though.
Not a bright idea...
Methanol
Key Points
Fire
Flammable; burns with a non-luminous, bluish flame.
May explode upon mixing with air
In the event of a fire involving methanol, use alcohol resistant foam or fine water spray and liquid-tight chemical protective suit with breathing apparatus
Health
Absorbed via ingestion, inhalation and skin exposure
Toxic
Short-term exposure may result in drowsiness, headache, confusion, sickness and abdominal pain, possibly within 30 minutes of exposure
Coma, shock and kidney failure may occur following substantial exposures
Short-term exposure may be irritating to the eyes, causing burning, stinging and watering
Long-term effects may include blindness, and following more substantial exposures, permanent damage to the central nervous system may occur
Long-term inhalation exposure to methanol may cause headaches and eye irritation
Methanol is not thought to cause cancer in humans
Methanol is not considered to affect human reproduction or cause damage to the unborn child
tom167
bucksvag.net
Mar 27, 2006
201
Milton Keynes
Yeh the maps been altered devon. Its odd actually, i can turn the meth on and off, and it black smokes more when the meth isn't on.
And no unfortunately it smells like potatos lol
