To tell you the truth, if I saw this problem again, I think my recommendation would be to take the engine/box out together and then pull the transmission off.
is on my list for next time here i can tell ya - so much easier that way i reckon
I ordered a new pushrod (£17 odd) today, I don't hold out much hope that the offending one is going to be any good after I've finished with it.
Fingers crossed mate.
On a different note. Did you ever get your aerial for your radio sorted?
No - that was the next job for KiwiCupra. :rolleyes:
I feel kind of sorry for the poor little thing sitting there on ramps.... :(
hehehehe they get ya like that so don't worry this place would be empty if they didn't, the worst thing is trying to explain why.
Woo Hooo!
The cunning plan worked!
Block of wood between engine and bellhousing by the starter motor hole. Rope around the offside driveshaft flange. Pull on rope very hard..................
I am a happy bunny :D !!!!
So, I happily bashed on, oblivious of the cold.....
New pressure plate fitted to the crank. Bolts torqued up. New release plate fitted and clipped in.... :D
But the f*ckup fairy was hiding just round the corner. :cry:
I went to put the friction plate into the flywheel to mount them both. It was too big for the flywheel. F*ck F*ckedy F*ck............ Tape measure out.
My existing clutch - 190mm friction plate on a 200mm pressure plate.
New Sachs Clutch kit from ECP - 210mm friction plate on 210mm pressure plate.
My real introduction to the vagaries of the Mk2.
what an absolute $h1tter. Always seems its one step forward, then 2 back.
Thing is how could you possibly know until it was off. Wonder how you'll be able to get round it - will the whole thing have to go back or will they be able to just swap the flywheel?
I don't know, Warren. ECP only had two listed for my engine, a cheapie and the Sachs kit - both 210mm - and Etka seems to confirm this. :shrug:
I guess there are more applications for the 020 box - I need to research.
I don't know if a bigger flywheel would fit my bellhousing - I wouldn't have thought it would be cheap from the dealer. (Dealer friction plate would have cost more than the whole Sachs kit - which was £86.10 )
*I really should have compared old with new before I fitted the pressure plate - I would do normally - in this case I didn't think there were any other permutations of this weird clutch arrangement......
All the research I've done this evening suggests my clutch is a bit of a bodge-up and maybe not original.
I'm guessing the flywheel and pressure plate is off a 1.6? But why fit an undersized pressure plate? :shrug:
In order to make this work, I'd need a 210 flywheel - which is 5mm larger radius than the current one......... Would the starter motor still work on it...??
I'd better double check my engine number - and the dia of the gearbox input shaft...
Any comments are welcomed..
i got the 190 friction plate as a 1.4/1.6 and the 200 pressure for some 1.6's and diesel ????
send us ya engine and serial codes and numbers dude we will dig it out for ya
