JP_LCR
Hi,
I am hoping to start upgrading my suspension in the New Year and would like advice please from the good people of SeatCupra.net. I have done plenty of reading before anyone points me at the search tool
The most helpful thread is the one Ruddmeister wrote and have seen his comments in other threads which have also been useful.
The requirements for me are to:
- Sharpen intial turn in from standard roll, before car balances
- Make car flatter through corner to give confidence at higher speed
- Improve ride quality over crashy standard setup (appreciate there is a balance between this and other requirements above)
The car is as stated in my signature, with 50k miles on the clock, never been on a track but would not rule it out in the future. I don't want to lower anymore than 20mm as Sheffield council have decided to not bothered fixing any of the thousands of pot holes, instead they have surrounded my estate with speed humps
not the flat ones, the ones which stick up between your wheels and make you cringe.
On the wheels/tyres I am either sticking with standard and a new set of Goodyear Eagle F1s all round or going for some 19 alloys on Falken 452s.
The routes to upgrade I was considering are:
Option 1 - Front and rear ARB 25/28 only on standard dampers/springs
Neuspeed £300 + fitting
Option 2 - Coilovers only
Cheap option - AP £325 + fitting
KW V1 £640 + fitting
KW V3 £961 inc free fitting
Option 3 - Koni FSD/Eibach, smaller ARB front rear 22/25, more of a road setup
Koni FSD £353, Eibach ProStreet Springs £107 + fitting
Option 4 - Coilvers and ARB all at once
Coliovers KW V1 £640 + fitting
ARB Neuspeed £300 + fitting
I cannot spend any more than £1000 and really would prefer to split into stages. Whichever option I choose I will also get the following done at the same time,
S3 front strut bace £57 + fitting
INA track density dogbone mount £99 + fitting
Grateful for any advice, on which to do first, or if any of you have the products listed above or (can recommend cheaper prices from anywhere,other products something I've not considered, would you buy same again?
Cheers,
JP
Cheers,
JP
