hmmmm I dont think it was even 2.75 when Bill measured, a definite restriction IMO
63mm when i measured it from memory = 2.5"
Your downpipe would be all new and full 3" if you had the BT from me, as your existing DP is not reused. Its all new on BT
what spec is the GT 30 hes running on that
just been sent a very interesting link in regards to a gt30 setup
scroll down for the dyno plot............
http://www.audi-sport.net/vb/showthread.php?t=64264
 Feck, once that thing hits 4250rpm
Bet its a pig to drive though. All or nothing.
Useless on UK roads, racecar only that thing. I actually think the smaller a/r GT2860RS may be the perfect turbo for UK roads and tracks, fast spool with a decent hit of power. Chase an Impreza down a twisty country road and the last thing you want is lag and slow spool, top end peak power means very little.
What puts you off? Who really 'needs' 380-400bhp anyway?I've heard quite a few people say the GT2871R is laggy. Not trying to put you off or sway you at all, just trying to apply some logic and common sense.
2871R with .64 is probably a good combo to go for, crank up the boost once rods are in.
Not sure if I'm going any further at all m8, might just leave it as is, haven't even used the hybrid GT2X in anger or know how much power it's kicking out yet!
My old 2871 was very laggy when compared to my Owens turbo, My turbo starts to pull from 2500What puts you off? Who really 'needs' 380-400bhp anyway?I've heard quite a few people say the GT2871R is laggy. Not trying to put you off or sway you at all, just trying to apply some logic and common sense.
