Heater with no heat
drummerchic
My heater will only blow out cold air and will not blow any air onto the windscreen at all. I have ecotronic fitted. Any suggestions ?
Mal
I agree, the only time I've ever had a problem with the heater was when my coolant was low.
Check this first. I actually had a leak from radiator, so if it is a persistent problem get it checked out, especially if you are under warranty. Don't worry unduly though, it does need a top up from time to time.
The other thing to check could be the fuse, although it seems to be working ok otherwise?
Hope that helps
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
Mine went through a stage last week of just stopping blowing altogether. Heat wouldnt work and the fan wouldnt work. Turned igintion off and on again (at traffic lights :blink:) and it worked fine! hasn't done it since! VERY strange.
