drummerchic
My heater will only blow out cold air and will not blow any air onto the windscreen at all. I have ecotronic fitted. Any suggestions ?
I agree, the only time I've ever had a problem with the heater was when my coolant was low.
Check this first. I actually had a leak from radiator, so if it is a persistent problem get it checked out, especially if you are under warranty. Don't worry unduly though, it does need a top up from time to time.
The other thing to check could be the fuse, although it seems to be working ok otherwise?
Hope that helps
Mine went through a stage last week of just stopping blowing altogether. Heat wouldnt work and the fan wouldnt work. Turned igintion off and on again (at traffic lights :blink:) and it worked fine! hasn't done it since! VERY strange.
