B3LSY
On the LCR inlet manifold were the injectors go threw the Mani there is 4 supporting bits of plastic to hold them in place does anyone know if they come out as I'm having it powdercoated any they will melt in the oven
Yep, or a bolt with a head the right size, and two nuts locked together on the thread...
the plastic will melt at 200c' in the oven, still can't get them out
You wont get them out i had to burn mine out and then clean the threads up, be very careful with the treads.
As said previously they bond them selves in you will not get them out in one piece i had a bolt made to fit them and using a 240v drill could not budge them, hence having to burn them out, and then buying a new set.
