nope its easy, pull down the back of the headlining and youll see that the base has iirc a 19mm nut on the back of it. undo this and it just lifts off. be carefull when putting it back on as it has a spikey ring on it which grips against the cars roof and if you do it up to tight it will push through the roof and then it will leak!
