Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
Right i have done a search and looked in FAQ bit but could not find the answer does anyone know how much lower a stock LCR is than a stock LC, also what is the difference between the front shocks apart from the ARB mounts, if i was to get some LCR suspension would the fronts fit in the hole in the hub? if the ARB mounts are in the way i will grind them off.
The LCR is 11mm lower than the LC, the shocks should fit and the ARB holes won't get in your way. This will give you the opertunity to run a LCR/S3 or R32 ARB at some point too.
Cheers willie that's exactly the info i was after, i thought it would fit, even better that the arb mounts don't need to be removed, there's a set in the for sale section but at £100 its a bit expensive i think and its in Liverpool.
They'd be mine and the price was put on for forum guidelines. I did say serious offers considered and at £25 a corner why not phone up a dealer and see how much they cost new :)
