Basically it's down to common sense and knowing how things work, I've seen the result of oil becoming carbonised inside the turbo after not letting it cool down properly, result is one blown turbo.
gonna play devils advocate for a moment.Personally I always let me car warm up before i floor it, but at the same time, what do the manufactures say? I am sure they would have a hard time selling a motor if they told the driver that you have to let it warm up fully and sit in you drive way with the car idling for 20-30 secs when you are finished.
i am not totally convinced that this is a total prerequisite each time i use my car, yes it does help and I can see how letting the oil heat up would help it do its job , but have the manufactures in there stress testing of these engines not have taken this into consideration
In addition would they not have fitted an oil temp guage with a warming in the first place.
I am aware of this warming up and cooling down, but the average joe is not, so how many cars are out there still going strong without this procedure ever being performed.
assuming you have one / need onealso, starting a car from cold and letting it idle can damage catalytic converters.
also, i read somewhere else that the oil pump will run on after switching the car off (on LCR) - think is in turbo timer thread. everyone saying you dont really need one because of this...
How about the complete oposite, how damaging is it to use your car without using the turbo. i.e. short runs where the engine doesn't get warm enough for you to use the turbo?
Very silly one here guys so sorry..
Anyways, my point is, i totally forgot that Id only been driving 6 or 7 minutes from cold before putting the pedal to the metal... (the temp needle was on half, and i know its only water temp) but im worrie about the oil not being warm enough .. ive never done this before, always let the car warm up properly. could i have damaged anything? and what, if anything can this cause in the long term.???
LOL and i thought i was the only one with warm up OCD![]()
