Its got casette radio, and CD player, 6 disc changer. I put the right code in,and hold, tap, press, about 500 times the PTY button but nothing happens!!! As soon as I press the program button it brins a small 1 up, then do it again and it brings a 2, then just says SAFE.. Im gonna punch the thing in a minute!!!
Keep it together mate, I think I have the answer:
Key in your number
Hold down the PTY/PROG button until there is a beep.
The code should be accepted.
Is Codifying a real word?
Its really not that hard, read through Coxw's scan of booklet, take your time, breath and everything should work. Good luck!
Serious im not dumb, I put the code in using the "1,2,3,4," numbers, then once the correct code it entered I HOLD the PTY button down, nothing happens? I press the PTY button down, nothing happens? I then press/hold the program button and it flashes SAFE, I then try again, and it says 2SAFE, and locks.... im getting annoyed... Im gonna take it seat dealers, best way?!?!
The code is normally found in the front of the radio instruction booklet on a little cut out section inside the cover page.
thats where i got it!!! but its not working im gettnig so pissed off and deading my 2 hour journey :(:(:(:(:(
Maybe its the wrong code, have you ever used it before?
I used to sell VAG cars and sometimes if we were missing a booklet we would just grab one from another car! :whistle:
thats prob whats happened then. so pissed off.. going seat tomorrow morning so they can reset it... *******s :mad:
It's not that simple, they will need to take the stereo out to get the serial number off then they will have to fax the factory in spain, you might have your code in time for spring. I would take the stereo out and put a better one in. Anythings better than the grundig that you've got!
I feel your pain :( being without a stereo is hell
Sounds like they've given you the wrong code for sure, The b@st@rds!
