I am sure there smaller because you have to change the silicone pipe that connects the charge pipe to the turbo when you do the ko3s conversion.
like I said on the previous page, all you need is 3 90 degree bends in either 60mm or 63mm. whatever you want.
On the third 90 degree bend, which goes down in the wing by the headlight, next to your horn, you have to stick a 45 degree bend on. then another 45 degree that which brings you to the intercooler.
Danny used 2 90 degree bends from turbo, and then a 45 degree one, because he doesn't have a washer bottle fitted there anymore. If you opt for the Golf 2 reservoir you'll need to fit a 90 degree one.
As danny knows, a little bit of searching where the best place to buy pipes/hoses from. Remember, cheapest doesn't always mean great quality. Especially as you'll be running fair amounts of boost.
Don;t think I can make it any clearer than this
to add crissy, the way you're explaining it is using silicone.
reason I wouldn;t do this is because silicone is just as expensive as the aluminum bends. So you might as well get a welder to put the pipes together for about 30 quid.
thats very good work mate where did you get the nipples from...
nice work, this part of the pipe (pictured goes straight to the ic or you have to add 45 bend?
imo: simple answer...no.
Why do you want to bend the alloy yourself? Why not get the 3 90 degree bends I said 4 times now?
if a bend costs about 15 quid then thats 45 quid and you've finished the entire part which is visible in the bay.
ive been looking on uk ebay and the only 90degree bends they have are only about 150mm, 6 inches long. surely that isnt long enough? these are what ive found.
http://shop.ebay.co.uk/items/_W0QQ_...286.m270.l1313&_odkw=60mm+90+degree&_osacat=0
yeah i see them mate need to be a good few inches longer than that dont they mate
got a felling that this might be a nightmear to get done but we will see ...
420mm (16.5 inches) is plenty to do the engine bay run?sorry i must be absolutely thick but you are saying that this will do?That's 420mm which is plenty!
