0000zoon0000
Hi,
recently I've bought a KKL cable for my Arosa 999cm3 (1999) , and VAG-COM showed following error: :blink:
1 Fault Found:
00533 - Idle Speed Regulation
09-00 - Adaptation Limit Surpassed
So I've cleaned the throttle body and this error disappeared. I did the adaptation also.
Before that the throttle valve angle was about 4.5 degrees. After it - 4.9 degrees. :think:
My question is this OK? :confused: What is the acceptable angle range?
Thanks.
Whats a KKL cable?
A cable that connects the car to a computer. Look under the steering wheel (where there are fuses) there is an OBD connector. Google the KKL cable and you'll see how it looks like.
