Im after the bigger of the two pipes to be replaced in your photo.
I have just replaced the vacuum hose from my DV for a new red 4 or 5mm hose. This will be the size you'll need for that pipe. Check the link
http://www.forgemotorsport.co.uk/content.asp?inc=product&catalog=0022VT
Im still waiting for an answer to my problem.
What I cannot understand is why would VAG put such soft pipe/hose work on vehicles that are running such high temperatures? Surely reinforced should be fitted from standard!
The hose's that you are both talking about come as 1 comlete set for Seat, So I'v been told and they are about £60.
Lee M I had the same hose split on mine and I replaced it with 8mm reinforced tubeing from Forge, they charge £12 for a Meter length and you only need about 70mm.
edmong1981 I'm not sure you will be able to replace that pipe with a straight pipe because of the tight turns in it, it might cause it to kink.
edmong1981 have you had these pipe's off before this occation ??
I think one of the reasons they split is cause the after market hose clips cut into the soft rubber hoses.
Before
Old pipe and off cut of the new Forge one
No mate its not split just dressing the bay. The pipe Im after slipped off the spitr today and just wanna get rid, very very soft, supprised its not split already.
Ive been on forge and found this
http://www.forgemotorsport.co.uk/content.asp?inc=product&catalog=0022A135
or any on the previous page to the above. The only prob is that they come in black or blue, I want red!
Yeah £60 is right!!!!!
What a rip off for a bit of hose! I cant believe they have to be sold as a pair its not as if they are joined. :shrug:
Lee M, just off the subject, what is your brake set up like? are they noisy? how long are the pads and discs lasting?
Looking to do the same upgrade as you.
