IHI vf24
jamiebennett81
whats in that 3k mate??
will be a little cheaper if you have a decent k03s to exchange
for around that price tag is:
CR Hybrid turbo
Forge TIP
Exhaust High flow manifold
oil filter
turbo fitting kit (oil water lines etc)
Oil
Coolant
stg3 remap
labour
this is from Bill @ Badger5
trust me, I would recommend him above anyone else on this site
power output from the logs I have seen is the car is on full boost at around 2700/2800rpm and holds well till around 6500rpm
power is around 280-290bhp max I would say with similar torque, more than a good road weapon against the likes of a Ford ST and scoobies
at least be prepared to double that cost if you are going down the IHI route.....
jamiebennett81
Excuse me for being dumb here but what exactly makes a K04 hybrid different to a normal K04? What are the pros and cons of this?
hybrid:
360 degree thrust bearing - allowing for stronger boost to be run and less play in the shaft
enlargened turbine inlet
enlargened turbine wheel
bigger comp housing
uprated seals
are the main things...basically allowing it to run higher levels of boost and flow omre
mikey_b
322
Manchester
CR Hybrid turbo
Forge TIP
oil filter
Oil
Coolant
stg3 remap
labour
dose badger5 do a ko4-hybrid???
jamiebennett81
I think so....but it wont be a straight forward fitment, as this means the re routing of IC pipework etc
for the cost Vs gains to be had, it would be better to go for the k03s hybrid route
Mar 29, 2007
1,207
Berkshire
Only thing that would stop me doing that if I had an LC would be the fact that you could probably sell the LC and buy an LCR and a stage one map for the same cost. Unless you're after the challenge I guess...
Cupra Ross
Breaks things............
May 15, 2005
1,380
Edinburgh, Scotland
LCR with stage 1 would give you about 260bhp. Even a relatively poorly mapped hybrid K03s will give that and it will be a far better drive than a stage 1 LCR. Boost comes in earlier, hold on stronger and torque is higher with a flatter curve.
jamiebennett81
would a hybrid k03s hold on stronger though.......even I think a K04 would hold it stronger due to it being a bigger turbo, despite it being slightly laggier...although even then a K04 I doubt isn't much laggier than a hybrid k03s
Cupra Ross
May 15, 2005
1,380
Edinburgh, Scotland
You have to remember that a K03s is already a "hybrid" turbo, its part K03 and part K04. A proper reworked hybrid K03s will hold boost far beyond the capabilities of a standard K04 and it'll spool up 750rpm earlier too.
jamiebennett81
no its not. A k03s is an off the shelf turbo, as from factory spec, all be it an upgraded version of the k03 which was on the early 2000 model Leons
a "proper" hybrid includes aspects such as 360 degree thrust bearing, largened inlet etc etc
jamiebennett81
I'm just talking about the costs - a hybrid k03 will pretty much get you to where a k04 already is that's all...
were losing sight of things here
we have suggested a hybrid k03s for this thread as it is a pretty straight forward swap, costs stay at a reasonable price and will give more power than a k04
going from a standard factory spec setup which has a k03s to a k04 is more work, a lot more cost and probably not all that massive difference for an "on the road performance"
as I said earlier, cost Vs gain
Cupra Ross
May 15, 2005
1,380
Edinburgh, Scotland
Hence why hybrid was in quotation marks. Its a hybrid in the truest form of the word, a K03s turbo has a K03 turbine and a K04 compressor.
