Had a look through this thread and i'm confused! Can some one please list all the bushes I need to order? My car knocks like buggery and is p?ssing me off.
Neil
Neil82, i am in the same position here. Nobody has posted with a complete conclusion to the bushing aspect of things. I am about to order all the parts i require as well as a suspension kit, so would be greatful if someone could conclude on the following:
As far as I can make out, (any 6L / MK4 model apart from the Cupra) will require the following to replace all bushings etc:
- New top mounts (get from main dealer, named "bearing surface")... apparently the originals will be knackered?
- Front susp arm / Rear bush off the TDI Cupra 160 x2 (~£7) - part # 6LL 407 183
- PowerFlex Front susp arm / Front bush?
- PowerFlex Anti Roll Bar bushings (front and back?)
If someone could tidy that up correctly...?
These are the options available from PowerFlex:
Can anyone tell us what diameter ARB Bushings are for what car? I am assuming the 19mm bush is for the cupra / cupra TDI? I have a 130 PD Sport, would I require the 18mm?
u can use sport suspension kits and 40-th profile. In Ukraine, where I live, roads are low quality and majority of
