Donnyboy
The Candy Man
Mar 15, 2005
1,558
renfrewshire
Anyone with a sunroof on their Mk2 Leon help??.
When you slide it back. Does it go right back or can you still see some of it from inside the cabin? If you look from above when open. How many inches of glass can you still see?
Cheers.
This has puzzled me a bit too, when my sunroof is fully back I have five and a quarter inches of glass/rubber seal visible from the outside.
it defaults to a wind break position, when it gets there twist the button and hold it the sunroof will then go all of the way back at least it will if its the same as the Golf.
I'm glad others have sunroofs, I want one in white or red possibly yellow but must have a sunroof !
It is the same as the Golf. The default position is not set full back to prevent wind noise when driving. I have tried driving with it fully back na dit gets very noisy at low speeds.
It does do that. You can't go over 30mph with the sunroof fully open though, the noise and vibration are terrible. In fact, even in the "wind break position", going over 90mph will make the whole roof vibrate and go up and down. :blink:
Even my 2002 Xsara doesn't do that. And yes, it can go over 90mph. :D
I thought all sunroofs were like that ? mind you some drag the cover back with them too and hide most of it
Thanks, I will try this
the drumming will stop if you crack open a rear window. (fine if theres no one sitting in the back!)
I tend to have the rear windows open an inch along with the roof and it stops the vibration.
Thinking about this, the cars that I have had in the past with a sun roof had a little spoiler that popped up at the front of the hole in the roof as you opened it.
Thanks for all the replies. I only noticed the other day that it didn't go all the way back.
I'll try the thing with the switch at lunch.
Indeed, but it shouldn't be like that. Not if it were designed properly in the first place anyway.
No, not all, but many are. Unfortunately, that's what R&D cost shrinking does.
The Leon has that too, it springs up when you slide the cover back. If you press it down whilst driving at 30mph or more, you'll be impressed at how much the air flow and noise change.
Is the sunroof worth getting? When closed is it solid or glass (transparent) or both? Does it add a lot of weight to the car? Is it well designed?
I'm glad I've got the sunroof and use it all the time. Its good to just tilt open for fresh air...... or to slide back for some open top motoring and wind in the hair.
It also lets some more light into the cabin even when closed. Its dark tinted and I've never had a problem with sun glare.
cupras with sunroofs are very rare, motopoint have a black one, there is an orange one for 22k and then 2 white ones on pistonheads, i'd prefer to buy from a trader but until I can find a cupra with the sunroof my search goes on !
Hi all sorry to drag this thread back up but ive got a 58 plate Cupra and this 5 inches of sunroof has been bothering me, how do you twist the button and hold it? where do you hold it? mine just goes all the way round and stays there??
Utterly confused.
Utterly confused.
Twist it until it stops in the slide direction, then once it's opened turn it more. You have to be quite firm with it. To be honest as soon as it's fully open it starts drumming over about 30-40mph anyway.
You are a star, works perfectly!
Thank you :)
(if only i could find the delete button, sorry for the double post)
