a tuning unit can easily be removed for warranty work or fitted to another car or sold ,i have also had a unit that plugs into the obd port that has 3 maps on it and when you change cars you can get new map/cables,with a remap a dealer can overwrite it when in for servicing,also a reply to other posts the mpg is correct is as doubters say they only ever overfuel you woyuld expect the mpg to read lower not higher so how does that work?
Quite simply, the tuning box is injecting fuel that the ecu doesn't know about, so as far as the ecu is concerned the car is doing x number of miles for y litres of fuel used and calculates accordingly. But as it doesn't know about the tuning box dumping a little bit extra in the calculation is meaningless. So your car shows a mpg figure that would be correct for normal running but is actually overly optimistic due to incorrect parameters.[/QUOTE
a tuning unit asks the ecu for more fuel and gets it ,that is why it accelarates better ,so how can the ecu read the signal and give the tuning unit more fuel but cant work it out through the mpg ?as it knows more fuel is being used lower down ,a tuning unit then asks for less higher up the rev range as there is so much unburned fuel that goes through the system,as i have had a unit on previous and present cars i work out my mpg by the litres used not by the computer as this gives you an exact mpg![]()
As far as I understand, tuning boxes can work in a couple of ways:also a reply to other posts the mpg is correct is as doubters say they only ever overfuel you woyuld expect the mpg to read lower not higher so how does that work?
They use the fuel temperature sender, not pressure. The temp of the fuel supply affects the fuel density and therefore the amount of energy available in a set volume, for which the ECU has maps to compensate - the amount of fuel injected varies depending on fuel temp. Fuel temps can get pretty hot, on the PD TDIs at least, some of the fuel runs & returns through channels in the cylinder head, which is why they have fuel coolers to cool the excess fuel before it returns to the tank. If the ECU sees the fuel temp going over a certain threshold though, it will start cutting back - so the resistance values of these boxes have to be chosen carefully in order to avoid a fault being flagged (with geeky hindsight I think it was 150 ohms for a PD 130if you buy for under £100 it will be an analogue unit that plugs into the fuel pressure sensor
)The TD PowerBox works by modifying the electronic signals that control fuel pressure produced by the VP pump in order to optimize engine performance. The TD PowerBox increases fuel pressure at the pump to compensate for lost pressure as fuel is distributed to each injector. The increased pressure enables injectors to respond faster during acceleration. While actual injection pressure is not increased, the pressure required to activate injectors is readily maintained.
The TD PowerBox includes the complete installation material you need. The TD PowerBox is easily installed at the the Electronic Control Unit (ECU). With the instructions provided, an inexperienced driver can complete the installation in 15 minutes. The TD PowerBox will not override the safe operating parameters of your engine and does not change or interfere with ECU functioning.
VP pumps - doesn't apply to PD TDIs then![]()
sorry i posted the wrong info
With the PD (Pumpe Duese) or direct unit injection system, the diesel fuel is heated to a very high temperature due to its thermal properties. The direct injection system has a temperature sensor that communicates with the Electronic Control Unit (ECU). When diesel fuel is heated to substantially higher temperatures, its density decreases. When this occurs, the fuel temperature sensor communicates the change, and the ECU compensates by injecting more fuel for combustion.
This is where the PowerBox intervenes. Integrated electronics communicates a higher temperature to the ECU, causing more fuel to be injected. The additional fuel is burned along with the excess air, which leads to a proportionate increase in output. The increased fueling will not override the safe operating parameters of your engine and does not change or interfere with ECU functioning.
Given that the ECU just measures the resistance across 2 pins of the fuel temp sender to work out the fuel temp, how else can the box function, other than by altering the resistance value presented to the ECU?this is not a resistor it is an analogue chipped unit
That couldn't be further from the truth - I've probably got more intimately involved with fuel-temp based devices than most on here, as ages back I spent quite some time researching and making my own for my PD130 - there's even a post somewhere on here where I list the part numbers of the OE connectors from VW that are used to connect to the temp sender, plus my findings with testing various resistance values - both with bypassing the sender completely, and leaving it connected in parallel with a second resistor to try and reduce the actual vs. reported fuel temp differences to reduce smoking when the engine/fuel is started from cold.your comments are typical of people stereo typing tuning units without ever using one or buying one of the £20 ebay ones and judging eveyry unit as the same,which they are not
You have to love some of the wording in that info don't you.This statement intrigues me though.
What is this "excess air" you speak of, and where does it come from?
Diesels always run on a very "lean" or air rich mixture. So not all of it is used during normal combusution but add a bit more fuel and you can get some more power to a point, but add too much and you get lots of smoke as theres no longer an air rich mixture to ensure all the diesel burns. But yes i agree the cheap tuning box on the fuel temp sender most probably works just as well. A more expensive one will most probably have some sort of timer to delay it's switch on to allow the engine to see normal fuel temps during cold start ups and similar. The VP tuning boxes actually work on the fact that the vp pump has stroke sensors in it so it works out how much fuel is injected that way. The tuning box works as a resistor across these sensors (but with a timer circuit to stop fault codes during start up) which makes the ecu think the pump is not pumping quite as much as it's requesting so it makes the pump pump further.
to be honest the text is from the supplier i had in germany ,it is the manufacturers claims not mine ,at the end of the day the poor guy who started this thread has had it hijacked to such an extent he is tottally confused ,obviously you like a good argument or work for a remapping company ,please remember forums are about individual opinions !!!Yes, I know that. But by design there is excess air provided during combustion, and using this excess air to burn more fuel moves the operating parameters for clean combustion closer together and you end up burning fuel incompletely, and produce excess soot.
But our friends statement "The increased fueling will not override the safe operating parameters of your engine and does not change or interfere with ECU functioning.", while factually correct, is meaningless in regard to excess sooting and problems related to that. A bit like saying "Fitting lowered springs to your car will not affect the rolling circumference of your tyres, and will not alter the speedometer calibration.". Factually that is also correct, but is a pointless statement because it's irrelevant.
Adding a tuning box does not interfere with the ecu functioning, merely forces the ecu to use values that are incorrect while still being within it's operational control. Additionally, adding a tuning box will not override the safe operating parameters as it does nothing to impact on turbo rotational speed, does nothing to alter any parameters which are controlled by the ecu such as engine speed, injection timing, boost levels, oil temperature, coolant temperature, radio station reception, climate control operation, and any number of unrelated features.
No, I don't work for a remapping company. And I admit I like a good argument (or debate) but the main gist of my point here is that so much misinformation (or misleading information) is being used to big up a product which basically just dumps extra fuel into the engine. So I doubt that the OP is confused, more likely he now has a more reasoned opinion and answer as to the question he asked.
And while forums are about individual opinions, that's really all they are. Opinions. Unless they're backed up by facts to validate them, of course.
tuning boxes just trick the ecu to throw more fuel in, or just boost the total fuel pressure, which is great if u wantt to break things, get a remap done everytime, youll only waste your money on a box then more money fixing the things it breaks! i do maps at £250 all in with lifetime garantee
