WOW! just read through the hole thread. this is truly mint! weldone mate
on vortex and caddy forium
not mutch to only a dam pipe arrived today ,
so thought might as well do the rear 4wd sorted , did the service then made a quick shifter, as i could find ought else to make one with
this my friend will control my rear fluid drive haldex unit , 50/50 50/25 50/0 perfect for lauch moterway and normal driveing tested it out yesterday and really chuffed , and no ecu or can/bus outputs or abs needed :lol:
:clap: nice.....
the "handles", are they a ........B&Q Racing item :whistle:
:clap: nice.....
maybe unsure what there oringly off tbh , as i couldnt find a small pool ball lol , but like anything else it dose the job nicely and saved a nice headace and money 600/800 for a haldex controller cost me 3.50 lmao ,,,:lol:
is that manually altering the haldex then ? love to see how that works - interesting - ooh what about fluid pump etc ?
by the way i have a full case of pool balls here if you want a red/yellow one :p 8 ball's gone already :p
yep it works fine i also did a bit of testing , which evern when the haldex is set to 0/and front wheels are 50percent u get get a small percent to the rears which lasts 10seconds , and when full pressure is applyed 50 rear and 50 front it lasts for 20seconds ,and the prime pump dosent need to run all the time only for a quick prime as inside the haldex the pressure relief valve keeps pressure for either approx 7/20 seconds , enoegh for a good hammering down the track lol
little video of 4wd for you too
http://tinypic.com/r/wj6s2h/3
love to see how you have it rigged up at the rear for future reference as i was told the primer pump runs constant topping up to keep it asll in check hence the expensive add on controllers - be handy if there's a manual bypass for it all for sure
superb job though and wheels rolling - nearly testing time then i guess :) :clap::clap:
This is the only build thread I have ever seen that competes with the nutter who put two vr6's in a lupo!
Highly impressive!
wow i remember seeing that read evern thow putting vrs in a lupo , putting one in the rear would be better then adding more weight and bothing engines pulling agaist each other , if id had a go at a lupo id have thown a hyabusa 1300 moterbike engine in with a turbo ,, :)
cheers flepper , hadlex is a neat idea , and all fluid controlled , little like a auto gearbox with clutch packs,i think if i tell everyone then sales would be down on custom controllers lol , but with a small bit of electrics and a 4.00 item , job can be bypast at ur own risk , as trying to run the haldex in permint 50/50 would over heat the clutch packs due to oil pressure over heat and over load load of the constant stepper moter :D
don't know if its been mentioned, what ECU is this using, is it the engines OEM ECU or is it a stand-alone ECU?
who is mapping the ECU?
ur a little off , has ive no ecu/no no standalone runing the rear haldex , best thing ive found too ,because its now manual , i can possible select 4 settings either 50/50 50/30 50/10 50/0 very simple :happy:
sorry, you may have misunderstood....
not mapping for the Haldex.... imeant mapping for the engine in general... so the engine runs to its full potential?
that's what got me, i couldn't see where/how you a lever to adjust it as i thought it was all fluid/solenoid controlled from a main pump etc
good to see it rolling though - driven it up yet ?
right i thought it was a bit strange may have mis read it wrong ,(easy done with me lol)
regards the engine , i never had the engine harness/loom or ecu so i thow a quick one togther and used a megasquirt 1 v3 standalone with wideband inovate for the tuning , as i did a bit of re search into these engines , and theres only mk3 2.8 and the mk4 2.8 12v/24v that were but with forged cranks and strong internals , as the 3.2/3/6 v6 have problems with timing chain failure and cranks snapping , plus the block walls are a lot thicker too ,
so with a good tuine these babys can handle 600bhp , as these engines were firsly built as a deisal with strong rods , then changed on the production line to petrol , long u you lower compression its all fine , i know a lot of people go to exspense in buying custon rods and pistons , but i ask myself why?as i first did a test on a mk3 2.8 vr6 stock engine and gearbox , just thow a turbo kit on it , and standalone to tune , only got to 10psi and engine compression was too high , so cut and made a headspacer to lower it to 8.5.1 ratio , totaly differnert , i got 400bhp and it blow the gearbox in 3rd gear , nice bang crunch :cartman: that was at 27psi of boost , engine had no problems at all , so after a bit of messing we thow the later 02m gearbox on it 6speed , just used 2wd , as these take 500bhp , then testing it , great short gear ratios runing 30psi of boost , all was well keeping the afr table 12.1 , the only bad thing the 02m run a crap dual mass flywheel , which dont like hp , and to convert to single mass , u need a bank lone lol , so in a word , with good tuning these are good engines for outputs in terms of power :D also the mk3 vr6 turbo was runing 215 35 18 tyres and at 100mph the tyres would hold to the road , gives u an idea the amount of torque and power they produce
yes ur right it should be lol , but now its not ,,, :) mot is friday if all goes well , then its tunieing stage time , ill start from 250 then 300 etc and see how it feels if all seems good hoping to aim for a good 450bhp , that leaves 150bhp spare lol be nice to know how it feels runing 2 wd to 4wd as this is a first attempt at somert like this , lol
