Deleted member 19366
Not really as the split will open more under boost the ecu reads this and throws up error code and car goes in safe/limp mode. Switching engine off/on resets the code until it happens again. Easiest way to test for leak is to get some soapy water in a spray bottle, start engine and spray hoses with the water and look for bubbles. Or see if any codes come up on vag-com, the code normally gives you an area where the leak could be. Failing that take it to your nearest vag specialist and ask them to pressure test the car for boost leak
