• Forum upgrade today 15th October from 3pm: Hi Guest. We are deploying an upgrade to the software that runs the forum today. It could take up to three hours. We're sorry but you're going to have to hold off on your CUPRA / SEAT fix while we work our magic. Thanks for your patience. Discussion here
questions about tdi150 chips
dan87fr
hi all ive got the leon fr tdi 150 im thinking about chipping it but have heard mixed reviews.whats the best chip to put on the car and are the 150's known the wreck cam shafts once chipped also because of the extra boost will i need new boost and intercooler pipes
Dyscontinued
1,142
Leeds
Can tell you now that 95% of people will say go for a remap not a chip.
Also, it's your clutch that you need to worry about, more than 300lbs on a remap will cause it to slip more than likely.
The next thing people will say is, have a search, there's plenty of threads on this both here and in the Mk1 section. We won't be able to tell o anything that's not been said before.
sssstew
Editing your spelling
Dan - invest some of your own time and have a read back in the TDI and TDI tuning for all the information and views on the best remap for the car. Everyone has their own opinion which has been covered many times before.
With regards to the chocolate cam, yes theres been threads about this also, have a read back through.
Bigbhp18t
A chip & a remap will return the same results at ther end of the day as they are the same thing just with differing methods of getting the new software code on to the ecu.
A remap wont wreck the cam shafts, but if the cams are well worn the remap will show them up as a fault or finish them off, The same with your turbo and clutch. The main worry with the 150PD are the boost pipes and the crap joins.
Ben
SHADY-NINJA
993
London
www.airconmedic.co.uk
one thing i might worry about is your clutch and you have to be able to stop the thing with better brakes and then sort the suspension if you want to enjoy it round the bends and corners.
it shouldnt cost the earth to do that.
S3 AKR
livin' the dream!!!
Jun 30, 2004
1,453
Colchester, Essex
Did mine with Revo when it was new - well, with 5k on the clock - and the clutch lasted till 25k ish. Uprated clutch is fine but pricey and worth it. No other issues and its now on 80k miles. You don't need to do the brakes for every day use, but its still a worthy mod for all the reasons suggested. I only uprated mine recently and its made a difference without a doubt, but it was still OK before.
Dyscontinued
1,142
Leeds
Do the brakes anyway, look better and bite better. Not been for a countryside run yet but I imagine fade less too, with grooves.
ChrisUK
Eat My Smoke
Oct 20, 2004
2,258
Liverpool, UK
My clutch started slipping on the way home after the remap lol (was only on about 20k miles). Got it done, then the remap made more aggressive.
Now on 50k miles & still running like a dream :D
