D_O_U_G_I_E
100% Beach Bum
Aug 26, 2008
481
Midlands
My LCR went in to have it's MOT this morning and it failed on a couple of VERY stupid things which can be sorted in seconds but it also came back with one very concerning advisory.......small amounts of BLUE SMOKE appearing!!! :(
Now from my limited amount of knowledge l'm asuming that the blue smoke will be caused from worn rings or worse....a damaged cylinder head! Any ideas or thoughts guys?
Have a look for the smoke yourself. Warm her up and let her idle for a few minutes, get a friend to rev the engine whilst you watch.
Search the forum for "blue smoke" youll find a few threads on this which should help
BALLS!!! A couple of friends have said they think it will be a new turbo too (which l REALLY can't afford at the minute!) but l was thinking/hoping it might just be the seals of the turbo that need replacing :confused:
Does anyone know of any tests l can run to figure out what it might be? l'm guna run a compression test later to establish whether its the rings or not, but l'm lost as to what else l can do to figure it out!
There is a place in Derby that does Turbo Repairs, they may even have a 2nd hand one?. I think it's called The Turbo Centre. Not used them myself, but have seen them advertised before.
Ken
Is this not an excuse to get a bigger turbo :D
This is true, but l've just thrown out loads of cash on a holiday for me and the misses and l can barely afford to replace the wiper blades let alone put a bigger turbo on! :happy:
That said.......l might just take a cheeky look at the price options anyway...:whistle:
£700 exchange 12 months ago
I think Backdraft are similar.
Std turbo was around £450, again based on exchange unit I think.
Hope you get sorted :)
Do compression test done 1st to check piston/rings. Could be stem seals as well. Have you oil and water level checked as well.
Have ic pipin inspected for excess oil.
