RR graph is it running "LEAN* - YES! - now with logs
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
I have played with over 12 rolling roads across the UK and I have found to take fly wheel HP with a pinch of salt. One DD dyno gave a 164 wbhp and 205bhp at the fly, if we are working on 15% lossess then the fly bhp should have been close on 190bhp?? Then another DD rolling road and another car gave 187wbhp and 217bhp at the fly? Using the maths from the 1st DD dyno of whbhp / 0.8 = fbhp then the 187whbhp should have made 233bhp at the fly not 217bhp? Both dynos ran in shoot out mode and the cars both Golf mk4 AUM 5 speed.
The rolling road I use will give the same wbhp time after time, but the coastdown can vary up to 8bhp on the same car
We need to be looking at the wheel bhp and the exact wheel bhp gains, plus we need to take in to account the correction factor one correction will give a uncorrected 200bhp wbhp 202wbhp corrected and another factor could give 206bhp corrected.
I found the following links which are really helps getting your head around this dyno stuff.
http://www.pumaracing.co.uk/coastdwn.htm
I can comfirm the gear cost down in 3rd, 4th 5th & 6th can differ from 19bhp in 3rd gear to 43bhp in 6th gear. The power run in 5th gave the most realistic coast down result on a stock Leon 150pd.
An few more links
http://www.pumaracing.co.uk/trans.htm
http://www.pumaracing.co.uk/POWER3.htm
http://www.pumaracing.co.uk/setup01.htm
Not my write ups, just wish I could do a write up like them but I am crap at putting what I know in to text, I was gifted with a good gob..lol
And a really good write up from JKM http://www.jkm.org.uk/performance/dynotesting.htm
Ben
oh god, another link to Puma... like he's the be all and end all of dyno's
:shrug:
pinch of salt req'd for every occasion and input.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
What do you reckon to the requested fuelling in 031, Bill?
too lean... up to 4krpm
I would want to see 0.90-0.95 under throttle until we see some boost produced and then wind to 0.80.
its too lean on its initial spool imho.
CF's are too high on that first log.,.. nasty
May 13, 2007
1,017
Denmark
Ok, cause my own LCR does indeed follow requested lambda, but from what your guys are writing, I also have problems with the values, but the car have like zero CF across the cylinders.
super_electric
Ps3 Tag: nixonoioi
Aug 20, 2007
748
North Yorkshire
Have you contacted Damian again, Richard?
Yep just said he has spoke with OC.T who do the re-maps and can not really up the fuelling anymore that it has been? And that all the settings are done by OC.T and then just sent over loaded on to what ever car and he just tweaks them where needed….
don’t what people to think I am having ago far from it Damian is a really nice guy just want my car sorted and running how it should be
Did mention that’s it’s the ECU requesting the fuelling but Damian and OC.T said if it was the map then the torque would have been effected?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
............. but Damian and OC.T said if it was the map then the torque would have been effected?
Sorry, I can't see that! The right hand column, requested fuelling, is what the map specifies...
Code:
Wednesday	19	August	2009
1ML 906 032 		1.8l R4/5VT         0001
			'031
RPM	Lambda Factor	Lambda Factor
 /min
2080	0.977	1
2240	0.977	0.969
2440	0.961	0.953
2680	0.945	0.953
2960	0.961	0.953
3200	0.945	0.953
3440	0.938	0.953
3640	0.945	0.953
3920	0.953	0.953
4120	0.945	0.953
4320	 0.93	        0.953
4520	0.969	0.953
4760	0.93          0.93
4920	0.867	0.813
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
who is OCT?
map is plain wrong as is what he said
maybe you need to seek a mapper who can do the job right
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Sponsor or not - he clearly doesn't know what he's talking about...
Suggest you get it cleared off, back to stock & visit somewhere with proven code (OCT is good stuff normally)
But he should have already pushed this back onto his code suppliers - but I guess if he's not technical enough, he won't be able to convey what the problems are.
You're spoiled for choice for alternates, there's no need to drive a poorly tuned car.
