Page 6 extract:
MOT Inspection manual said:A tread pattern is the combination of plain surfaces and grooves extending across the breadth of the tread and round the entire circumference.
The tread pattern excludes any tie-bars, tread wear indicators, or features designed to wear out substantially before the remainder of the pattern, and other minor features. Grooves that had not been cut as deep as those containing the wear indicators when new, are not to be considered as part of the tread pattern.
Each side of the central band of the tyre can be devoid of tread (i.e. ‘bald’) and still meet the pass standard.
The contents of post 19 were compiled thoroughly, using offical Dft/VOSA/VCA/Type approval sources, and are confirmed as corrrect.don’t rely on the info you find on the tester’s manual on-line, the test centre terminals are constantly updated, possibly outdating the on-line info depending on when it’s updated.
All previously included within post 19 (page 1).
but don’t rely on the info you find
Covered in C&U, as amended.And cut tyres were also illegal at that point, no mistaking that one, is there?![]()
This has nothing to do with European law, it relates to C&U - see DfT email.You’ve seen the amendments in European law on tyre regs, and they go on for ever.
Any changes in legislation will have superseded any previous regulation from 2003. The only thing you can base it on is the current regs, or anyone’s interpretation of them
You might not be happy about it - that much is clear - but the tyres were roadworthy, as confirmed by the highest authority.using offical Dft/VOSA/VCA/Type approval sources
Old statute, rules and regulations are not thrown awayYou can’t, as far as I’m aware, research what was or was not road legal in 03, only speculate, and that once again would have been open for interpretation.
IncorrectYour own take on tyre regs was only to allow E marked tyres on the event in latter years
RobT said:Maybe it's worth having a rules refresher
1. Cars to take part in a fully road legal state - MOT\'d and Taxed
2. Tyres - MSA List 1A and 1B allowed and all tyres must be E-marked as road legal in the UK.
I have not done a U-turn.now you seem to have done a “U” turn on the necessity of E marking, which could open the flood gates to people trying to use tyres similar to those used in 03, yet I think you’ll still try and implement the E marking regulations which points to double standards.
I've had to listen to this for over 6 years now, like a broken record. I was being accused of cheating. Forgive me, but it was time to put it to bed, for good.Quite sad folks have fallen out in such a big way over such an inconsequential thing..
It's never really been an issue with comparability to 1A (night and day), but there remains a subtext that DOT Hoosiers are more effective than 1Bs / 888s, hence I say use the damn Hoosiers. I don't believe there to be any performance advantage.One things remains fact is a Hoosier tyre is not comparible to a regular road tyre like a toyo t1-s, goodyear eagle f1 etc etc
I won't be labelled a cheat, directly or indirectly (post 17). I didn't start it, I've flagged to Rob that sheer competitiveness should not override friendships, but this appears to have fallen on deaf ears.Get a grip... please. Its not worth the hassle is it?
Long term friendships have been ruined becasue of the feud.. and as a friend to several of you, as a bystander, its all very sad to have seen happen.
{watches from a distance}
Incorrect
It was Rob's assertion, over the last 6 years, that no e-marks = non-road legal.
Commentary from Rob can be found in 2004 -see the posts at the start of post 18.
In the period 2004-2006, Rob's ongoing pressure and commentary meant e-marks became accepted as gospel over time: the 'unwritten' participants' rule. Meanwhile, the Events Manager made NO assertions either way, nor did he update the event rules.
All the while, I'd driven on the roads several occasions on Hoosier tyres, unaware of any non e-mark issues. I began to believe it was something I should not have done.
2008 saw the e-mark requirement formalised, prompted by Rob:
Rob's input ^^ was compiled into the Sept 2008 Curborough rules... (the 1A and B MSA tyre references were dropped).
As you can see, it was not my take.
Rob's relentless disputing of the 2003 event results (April-July 2009), and threads such as this, then pushed this e-mark issue to a head. Cue impasse. Following a necessary investigation, the 'e-mark requirement' for roadworthy status is now proven as incorrect.
The full facts are now above, and we can see that mandating e-marks was not my doing, and had no factual basis.
The question is definitely whether to unpick future event rules to re-permit non e-marked road tyres, or even just name DOT Hoosiers complying with C&U, to avoid opening up to the completely unknown. My personal view is to allow the DOT Hoosiers. For those wishing to try something different to the 888, I say fill the place up with them! The floodgates can be controlled easily, if, as and when the rules are changed, because the present rules mandate an e-mark.
It's too late for the next event - rules need stability, and 10 days to the next event is too short.
So there are no double standards being operated at all![]()
as this obviously goes deeper than wether a 'tyre' is road legal and seems to be about some 'rules' somewhere then all i can suggest is to learn from the experience in street eliminator when drag radials were being utilised again.
after several meetings/altercations and the loss of several main compeitors the class rules were altered
firstly defining what tyre style/tread and markings had to be present in standard form
a list (accessed every official meeting (2 a year) of any additional excluded tyres that wether marked correctly or not were excluded by the majority ruling as voted by the drivers themselves
end of the day using the 'road legal' aspect of any tyre limitations/rules is open to many interpretations especially when you add another country supplied option etc and will only cause (and does) many arguments over advantages/styles etc especially from those that can't use it to their own advantage
if it's for any form of class/rules then it needs to be defined it in black and white what IS and what ISN'T allowed or it's asking for trouble
