Feb 20, 2005
3,476
Telford ay it...
Anyone fitted a 20VT exhaust with a mid-facelift ibiza? I have the exhaust cut out and need to know if the tail pipes will exit through it, will look proppa gash otherwise. A pic of a 20VT back box mite help also.
Cheers Ant, would be good to see.
If I can 'make' it fit, ill be well chuffed! If I cant, I will have wished I bought a new standard back box.
Hope these are of some use (maybe, maybe not!):
Cheers mate, from those it doesn't look like its going to exit through the cut out.
You have to use those fandangled sleeve things to join the pipes then? Might have to buy some of those in advance if so.
It came with the sleeves, so yeah, it does look that way. However that exhaust never made its way onto the car, so I couldn't say for certain.
Its all fitted, doesn't exit the cut out but hangs under the bumper just touching it.
Slight problems when fitting as the CAT pipe was to small for 20VT middle section, I had to make a sleeve from my old back box to make it fit. Need to redo it when I have time as the sleeve is not thick, or long enough really.
