Throttle body de-gunged
Mar 29, 2007
1,207
Berkshire
I'd suggest to only do things like this if you're having stuttering issues etc. with the car. But then I am a conservative b@stard when it comes to doing random things to my car.
Jul 29, 2006
723
cumbria
www.facebook.com
I know where your coming from there mate,although,am sure i read a post saying it was a good idea to do every 40-50K miles,it's just so much more responsive now:),and at the end of the day its a 15 minute job that isn't too hard to do.:D
deejay391
Well 115k and I'm pretty positive it'll be slightly more then dirty, if its only a quick job sure its worth doing :D
sie77
87
I did it this morning and noticed something, the actual flap? (not sure on correct name) wasn't completely closed in a straight line, it was slightly open maybe by about 5mm. Is this normal or does it mean i need to get it aligned?
Thanks.
Jul 29, 2006
723
cumbria
www.facebook.com
Thanks.
All i can say is mine was fully closed mate:shrug:
I'd imagine it should be fully closed though:confused:
deejay391
Would imagine the idle revs would be higher/lower then normal if it was slightly open? Might not be open significant enough to cause and difference tho :shrug:
sie77
87
I think it ticks over between 700-800 but i do get a small amount of revs when i dip the clutch and change gear especially higher up around 4000rpm+ i've been trying to solve this issue before i get a remap.
Jan 3, 2006
834
East Kilbride
Thanks.
Mine was like that also...
Is there anyway to do the TBA without VagCom??
CupraString
405
West Mids
I de-smegged my thottle body this morning it was really really dirty, after following the how to guide I took it for a drive earlier and I can't beieve how smooth it was compared to how it was before. A must do if your car isn't running smooth at low revs
deejay391
I couldn't be bothered to take off the throttle body so gunned 300ml of carb cleaner down the inlet, was like a child taking cough mixture but it'll do it good in the long run!
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
HMMM lots of fluid in you intake manifold ready to be sucked into the combustion chamber, not really a good idea bud.
not a job to be taken lightly.
Very easy to do, if done right but very easy to do very wrongly, see above^^
deejay391
:happy: Nothing wrong with the way I did it if I'm wrong ill gladly drink the intake liquid if im wrong ill gladly let you know so you can do the I told you so dance :D
