Hi i have been having a boost problem for about a month now, where my car is not boostin at all it drives like its a 1800cc??
Befor it got to this stage it was just boosting on and off, now the TCS light stays on aswell as the EML.
The car was been maped by c-codes about a week befor this started, am sure the map is not the issue.
I have been reading alot about this type of problem and most cases its the n75valve or the maf sensor.
Parts i have replaced so far: 4x coils, 4x spark plugs, new n75valve F, New maf sensor, cheeked all hoses ect
Had my car vag-comed to day and this is the fault codes thats coming up guys.
Monday,31,August,2009,15:43:03:32585
VCDS Version: Release 805.4
Data version: 20090602
Address 01: Engine
Control Module Part Number: 6K0 906 032 AA
Component and/or Version: 1.8L 20VT EU3 0002
Software Coding: 10500
Work Shop Code: WSC 13367
Fault Codes have been Erased
7 Faults Found:
3 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00 - -
5 - Boost Pressure Regulation Valve (N75): Short to Ground
P1547 - 35-00 - -
5 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-00 - -
3 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 35-00 - -
9 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 35-00 - -
5 - Boost Pressure Control Valve (N249): Open Circuit
P1287 - 35-00 - -
2 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
P1114 - 35-00 - -
Readiness: 0110 1101
Dont know why the n75 valve is coming back??
Plz help me get my little pocket rocket running agen
Thanks for any advice or help Rab
Address 01: Engine
7 Faults Found:
P1425 - 35-00 - -
P1547 - 35-00 - -
P1117 - 35-00 - -
P1435 - 35-00 - -
P1421 - 35-00 - -
P1287 - 35-00 - -
P1114 - 35-00 - -
