They are convexed
Convexed are shapes that curve out
Concaved go in
A very good exampel of type before think.
They are convexed
Concaved go in
Most of the engine cover's are textured so you would get samll air bubbles under the surface which might get bigger.
The smoother the item you are covering the better the finnish you will get.
That requires some serious precise cutting and a hell of a sharp knife!
I must say that the stuff from ebay (i kindly followed D.Ks advice and bought it from the same place he did) is really good stuff
if you really want to clean up the latch area remove it first then sink in a smaller filler piece and trim around the edge ?
from above you'd need to look hard to see though anyway
Just a thought. The rear wiper arm could be the next victim.![]()
This should do the foil cutting a bit easier
