had m3's until the rattling drove me nuts and i filled em with foam to see if i could make em explode :) got smoothy dtm style ones now that are half the size of m3's
You know you have a Bitza mk2 when you want to change the rear plastic panels on the tailgate and then install the reflective rear panels, only to stop and find out there is a stupid screw which you can not remove because no screwdriver exists for it, and then you have to open the tailgate, remove plastic cover, cut the plastic rivit and then hit the end of the screw with a hammer until it comes out!
you no you have a mk2 when you have to talk to it and beg it not to go wrong and if it does the reward of optimax is on the cards
As a newbie may I just thank you all?
I have so many of these things happening to my old diesel Mk2 and I thought it was just me and it!
I feel much better knowing that I am not alone.
Does anybody know why the speedo would die at the same time as the clock starts running wildly fast?
(And what is the secret of the rear wiper, or does it just have a mind of it's own?)
hahah i was the same, then i found this forum and all my problems and they had already been answered lol!!
Ha I know it is, light is on all the time though.
Makes stopping more exciting though ;)
Was yours hard to sort out in the end??
Ollie
You know you have a mk2 ibiza when you sell it and instantly miss it and buy another, then swap that for what you though was your dream car (mk2 golf 16v gti!!!) then instantly want to swap it for another ibiza!!! although I know have a pug 205 gti 1.9 :-o(which i'll happily swap for an ibiza valver!!:D)
Ollie
Not 100% its fixed yet, not had chance to take it a decent drive.
Mine was the connectors under the rear seats, must have been a bad contact. Also cleaned the front trigger wheels. Pain in the butt really but Vagcom helped alot with finding the rear sensor fault.
Scares the poop outa me having the rears lock up, gets abit sketchy :drive2:
Ha
I know what you mean, the first time it happened it was a supprise
Now I expect it and adjust accordingly
Is something that need to get sorted though
Ollie
you know you have a mk2 beeza when you go to fix the 'surface' rust on your arches and find a bloody hole!!
