How did you wire up your twin headlights?
I've been think about doing this...
.G.
is a simple swap, the plug that goes into the old unit fits straight into the new one. there is one problem though. if your light are on and you flash it switches your normal beam off to turn high beam on, however if you were to keep your high beam on (as in push the stock out then both work together)
bumper comes off, old light out, new light in, plug and play![]()
I still don't get it... As I understand it at the moment I only have one set of wires running to the plug for my head light bulb, is there two sets or wires on the other headlight unit?
i.e. Is there eseentially a wiring loom with a multiplug on it below my existing headlight that I simply plug into a twin lamp unit?
What I have:-
What I would go for. (I know this shows a Xenon bulb, but essentially the unit is the same)
I can't find an actual wiring diagram online anywhere...
.G.
ok if you look at the back of your headlight you will see a plug. once removed you can remove the existing unit (with bumper off etc)
the new unit fits straight into place and the plug you take off from the old unit plugs into the new one...simple. another problem is you cant move the bulbs up or down electronically form the car. i will take a few pictures of the back of my unit for you
How much did you pay for the bumper?
.G.
thought it was a bargain so it will do until i get the cupra bumper. hate the pre-facelift one, would look silly if i had a cupra rear and stupid front
£42.99 including vat and p+pthought it was a bargain so it will do until i get the cupra bumper. hate the pre-facelift one
AviT[B said:[/B]urbo;2654612]sorry to disapoint you fella but the bumper in this picture is not a cupra bumper
the part where the liecene plate is should be black and with diffrent grills
