bugger , ive delocked mine, kept the bits , but metal disk is now inplace
howd iget rounf this then chaps
yeah that's what i though and seems we are stuck with out vag-com or the likes to recode.
garage couldn't/wouldn't do mine as system said wrong blade type.
not sure on this bit but what can i do..
my working blade is W3 and extra are W, they said not compatible!
udate have had my blank "NEW" key cut, guy cutting blade has told me i have a cheap copy blade and the metal is not right and so he managed to cut through at one point (not convinced it wasnt his fault) :( however it does operate the locks and fits into ignition :)
followed :
car is locked
- unlock with normal key manually at drivers doorlock
- IGN ON with normal key ... leave it there
- use NEW remote key to lock the car manually at drivers doorlock
- remove remote key from doorlock
- press "lock" at the NEW key, indicator lights will flash
- then hold the "unlock" for ~3 sec. and indicators will flash long
and the doors should unlock
- coding procedure should be successfully finished.
and now have a fob which locks and unlocks the car
just need to get my SKC and add the key to the system
also can the origial dealer of the car provide a SKC
also forgot to say Timpsons (in Pontypridd South wales) have a "Laser cutter for VAG keys" but could not cut my key because the follower on there cutter woulb not fit into the channel of my original key - the manager told me car manufacturer are doing this narrowing of channels to stop others "Cloning keys"
Hi mate,
How much mate for a new full key?
Thanks,
Rich
Hi
£50 - key based on genuine remote (part number 1JO 959 753 DA or 1KO 959 753 G or 1KO 959 753 N all 3 button 434 mhz )and good quality aftermarket keyhead with HUF blade and transponder 48 crypto. price is for brand new key and coding (extra costs - blade cut)
Genuine key head - +£10 to the price above
only coding procedure - £20
Robert
p.s. sheffboy as newbie I am unable to write pms - sorry
Hi
Robert
So it would be £60 all in? Remote+Key+coding?
