Had an interesting chat with someone very clued up on tuning the other day regarding this. Whilst the Seat Sport is bigger, apparently the pressure is not correct due to the size, whereas the Forge one, being smaller, maintains closer to the perfect pressure...the Venturi effect, apparently..I'm currently reading around a lot as trying to decide which FMIC to get myself, just found it quite interesting.
Pressure is constant unless you get a restriction within part of the system "Venturi effect" this is where some people change the "pancake pipe" for a 63mm pipe instead and have to hack a bit out of their bumper. Thus having a 63mm inlet and outlet therefore minimising the venturi effect. Unless the actual core of the intercooler is much smaller then 63mm then there isn't much effect.
I'd be more worried that they both have the inlet and outlet on the same side, thus reducing the efficiency of the intercooler itself.
Hey im now going to uprate the clutch also, does anyone know any good places to get uprated clutches from? or any other suggestions looking for a uprated clutch that will go with the original flywheel.
this is really good cose i am wanting to do the hybird ko3, some on here has got a g60 flywheel and vr6 cluch in a mk4 am sure of it,?
Hey, just thinking im haveing a full system from turbo back being fitted next week with 3" downpipe, will changing the turbo and manifold change the fitting of the exhaust or will the new downpipe still fit the same as it does to the standard unit??
k03 hybrid is same fitment as k03/s....
:D :D HYBRID COMPLETED :D :D
The car is with Bill at Badger5 getting remapped this week, roll on saturday :p
Iv got loads of pics so when i get chance will put a readers ride post up :)
cheers if you helped me out advise wise...
