And as for a 1.8 20VT Tolly? Will it sit correctly? As i'm about to buy them off an '03 LCR which to my knowloedge they're Eibach Pro Kit's and lowers about an inch.
I believe the LCR is a 1.8 20v at its heart, albeit with a bit of extra plumbing? So you should be fine for the front end, but the Toledo has got a whole lot more metal sitting behind the rear wheels. So not quite as bad as a diesel, but still potentially a bit 'squirmy'.
ahhh my tolly sits about an inch lower at front but sits more at back.....i've mentioned this before because it sits lower than any tolly av seen...![]()
The curious thing here is, the LCR weights more than the Tolly, how can this be?
I have a mag review which officially, the Tolly 1.8 20VT is at 1,223kgs. Odd, huh!
How did you mount the front ARB?
