My only concern is with this opposed to a proper kit is that the MAF isn't braced. The MAF is quite sensitive to vibration and knocks so might lead to premature failure. Might be worth making up a bracket?
My the bracket on the RamAir on my Mk3 Cupra actually broke... I cable tied it down untilI could fix it.
people i have spoke to jetex and due to high demand on these filters they have sold out and have ordered a batch to come in the end of next week just to let you all know
cheers
I thought about this myself. As it is the weight of the airfilter is only supported by the TIP, although it is very unlikely the worse case scenario is that if you go over too many bumps/speed humps/etc you could potentially pull the TIP away from the turbo bringing with it a whole world of pain and suffering which we all would do best to avoid. I'm going to make some sort of support today.
oooh i could see a group buy on here fellas.... mods??
I tried to organise a group buy for THS engine mounts ages ago and the Mods were'nt interested as THS are not forum sponsors. Unfortunately, neither are Jetex. :(
Where's your logs guys, come on. ;)
I use cable & pipe bandit to secure it. (metal pvc coated straping with holes)
Just as a temporary measure I've tie wrapped the end of the filter to the battery cover.
Not the best pics but there you go, it's actually quite solid but I intend to extend the section
after the MAF to centralize the filter and bring it closer to the wing so it'll do for now.
Tried to do some logs earlier on but got stuck in a massive traffic jam as my 'Test Track'
was closed in both directions. On nights tonight so I might try to do some in the morning
while the roads are clear.
Ok, some Vag-Com logs. All done in 4th gear.
The following three logs were from my PREVIOUS induction set up;
Code:
Wednesday	21	October	2009	10:37:03
1ML 906 032 A  		1.8l R4/5VT         0002
	Group A:	'003				Group B:	'020				Group C:	 Not Running
		RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME					TIME					TIME
MARKER	STAMP	 /min	 g/s	%	 °BTDC	STAMP	 CF	 CF	 CF	 CF	STAMP
	0	2160	34.11	73.3	22.5	0.4	0	0	0	0
	0.91	2320	51.47	96.5	15.8	1.41	0	0	0	0
	1.81	2520	73.36	100	10.5	2.21	0	0	0	0
	2.61	2800	104.78	100	0	3.02	0	0	0	0
	3.42	3080	108.08	100	1.5	3.82	0	0	0	0
	4.32	3440	115.67	100	4.5	4.72	0	0	0	0
	5.13	3720	128.69	100	6.8	5.63	0	0	0	0
	6.03	4080	140.11	100	9.8	6.54	0	0	0	0
	7.04	4440	152.81	100	12	7.44	0	0	0	0
	7.84	4720	157.78	100	12.8	8.25	0	0	0	0
	8.75	5000	172.17	100	14.3	9.15	0	0	0	0
	9.55	5280	179.75	100	14.3	9.95	0	0	0	0
	10.37	5560	186.94	100	14.3	10.86	0	0	0	0
	11.28	5800	187.86	100	15	11.66	0	0	0	0
	12.06	6000	191.53	100	15	12.48	0	0	0	0
	12.88	6200	192.44	99.6	15.8	13.28	0	0	0	3
	13.69	6400	192.14	98.4	16.5	14.17	0	3	3	3
	14.59	6600	193.08	100	15.8	14.99	0	3	6	3
	15.39	6760	194.17	98	15.8	15.9	0	2.3	6	2.3
	16.4	6800	29.25	14.9	1.5	16.8	0	0	0	0
	17.2	5480	11.92	9.8	5.3	17.6	0	0	0	0
	18	5400	14.31	10.2	4.5	18.4	0	0	0	0
	18.81	5280	13.31	9.8	5.3	19.21	0	0	0	0
Code:
Wednesday	21	October	2009	10:51:05
	Group A:	'115				Group B:	'031				Group C:	 Not Running
		RPM	Load	Absolute Pres.	Absolute Pres.		Lambda Factor	Lambda Factor	Bin. Bits	Bin. Bits
	TIME					TIME					TIME
MARKER	STAMP	 /min	%	 mbar	 mbar	STAMP					STAMP
	0	1760	13.5	970	990	0.42	1.991	0.945
	0.93	1800	79.7	2170	1040	1.41	0.961	0.961
	1.82	1960	92.5	2240	1200	2.33	0.953	0.953
	2.73	2160	108.3	2320	1360	3.13	0.953	0.953
	3.63	2360	129.3	2230	1570	4.03	0.945	0.938
	4.45	2600	151.9	2150	1850	4.94	0.899	0.883
	5.34	2880	184.2	2170	2230	5.74	0.844	0.86
	6.16	3160	182	2170	2160	6.65	0.844	0.844
	7.05	3480	180.5	2190	2170	7.45	0.852	0.844
	7.85	3760	178.2	2190	2200	8.27	0.844	0.844
	8.77	4080	179.7	2200	2170	9.17	0.836	0.836
	9.57	4360	181.2	2200	2190	9.97	0.828	0.836
	10.38	4640	180.5	2180	2170	10.78	0.828	0.836
	11.28	4920	178.2	2180	2160	11.79	0.828	0.836
	12.29	5280	179.7	2230	2180	12.68	0.821	0.836
	13.2	5520	178.2	2290	2150	13.6	0.813	0.836
	14	5720	172.2	2300	2090	14.4	0.844	0.836
	14.8	5920	165.4	2290	2090	15.2	0.813	0.836
	15.6	6120	160.9	2250	2090	16.01	0.828	0.836
	16.41	6280	158.6	2180	2090	16.81	0.828	0.836
	17.31	6440	150.4	2120	2070	17.71	0.828	0.836
	18.12	6600	154.1	2030	2020	18.52	0.844	0.836
	18.94	6720	152.6	1960	2010	19.42	0.821	0.836
	19.84	6840	139.8	1920	1930	20.24	0.821	0.836
	20.64	6960	141.4	1930	1890	21.04	0.836	0.836
	21.45	6960	12	970	1600	21.95	0.93	0.93
	22.44	6720	12	970	1070	22.84	1.991	1.047
	23.24	6560	12	970	1040	23.64	1.991	1.047
	24.06	6400	12	970	1030	24.46	1.991	1.047
	24.86	6280	12	970	1030	25.26	1.991	1.047
	25.66	6120	12.8	970	1020	26.17	1.991	1.047
	26.57	5960	12.8	970	1020	26.97	1.991	1.047
Code:
Wednesday	21	October	2009	10:53:48
	Group A:	'118				Group B:	'032				Group C:	 Not Running
		RPM	Temperature	Load	Absolute Pres.		Lambda	Lambda	Bin. Bits	Bin. Bits
	TIME					TIME					TIME
MARKER	STAMP	 /min	°C	%	 mbar	STAMP	%	%			STAMP
	0	1960	33	0	990	0.51	0.6	-9.4
	1.01	2040	32	95.3	1060	1.41	0.6	-9.4
	1.81	2240	30	95.3	1290	2.22	0.6	-9.4
	2.62	2480	27	95.3	1590	3.02	0.6	-9.4
	3.44	2760	27	95.3	1990	3.84	0.6	-9.4
	4.24	3040	26	78	2230	4.64	0.6	-9.4
	5.04	3400	25	78.8	2180	5.44	0.6	-9.4
	5.84	3720	25	79.6	2190	6.25	0.6	-9.4
	6.75	4120	26	79.6	2200	7.15	0.6	-9.4
	7.55	4440	27	81.6	2200	7.95	0.6	-9.4
	8.37	4760	28	82	2180	8.77	0.6	-9.4
	9.26	5120	30	86.7	2160	9.66	0.6	-9.4
	10.06	5400	32	95.3	2150	10.48	0.6	-9.4
	10.97	5720	33	95.3	2100	11.37	0.6	-9.4
	11.77	5960	35	95.3	2110	12.19	0.6	-9.4
	12.59	6200	37	95.3	2060	13.09	0.6	-9.4
	13.49	6440	39	95.3	2080	13.89	0.6	-9.4
	14.3	6640	39	91.8	2040	14.81	0.6	-9.4
	15.31	6840	42	82.4	2020	15.71	0.6	-9.4
	16.22	6600	42	0	1580	16.62	0.6	-9.4
	17	5560	39	0	1090	17.4	0.6	-9.4
	17.82	5480	39	0	1020	18.22	0.6	-9.4
	18.62	5360	39	0	1010	19.02	0.6	-9.4
	19.42	5280	38	0	1000	19.82	0.6	-9.4
	20.22	5200	37	0	1000	20.64	0.6	-9.4
[/QUOTE]
And these three are with the JETEX set up.
Code:
Sunday	15	November	2009	06:48:11
	TIME					TIME					TIME
	636.31	1720	11.92	8.6	30.8	636.7	0	0	0	0
	637.1	1800	31.39	81.6	18	637.52	0	0	0	0
	637.92	1920	38.22	87.8	15	638.42	0	0	0	0
	638.93	2160	51.19	92.5	11.3	639.33	0	0	0	0
	639.73	2360	69.31	97.3	6	640.13	0	0	0	0
	640.53	2640	95.61	100	0	641.04	0	0	0	0
	641.44	2920	102.86	100	0	641.84	0	0	0	0
	642.24	3240	112.06	100	4.5	642.64	0	0	0	0
	643.04	3560	125.31	100	6	643.44	0	0	0	0
	643.86	3840	133.06	100	7.5	644.35	0	0	0	0
	644.77	4160	144.69	100	10.5	645.26	0	0	0	0
	645.76	4520	158	100	12.8	646.16	0	0	0	0
	646.56	4800	163.64	100	12.8	646.98	0	0	0	0
	647.47	5120	174.89	100	14.3	647.87	0	0	0	0
	648.29	5360	188.78	100	14.3	648.69	0	0	0	0
	649.09	5600	194.94	100	14.3	649.49	0	0	0	0
	649.89	5840	196.81	100	14.3	650.3	0	0	0	0
	650.7	6040	197.47	100	16.5	651.1	0	0	0	0
	651.5	6200	200.94	100	17.3	651.9	0	0	0	0
	652.3	6400	201.03	99.2	19.5	652.7	0	0	0	3
	653.12	6520	202	99.6	19.5	653.52	0	0	3	3
	653.92	6680	193.78	98	16.5	654.32	0	3	3	2.3
	654.72	6760	184.61	99.6	17.3	655.12	0	3	2.3	2.3
Code:
Sunday	15	November	2009	06:28:11
	TIME					TIME					TIME
	0	2160	15	980	1010	0.36	0.836	1
	0.76	2240	92.5	2250	1130	1.16	0.953	0.953
	1.56	2440	122.6	2140	1480	2.07	0.93	0.914
	2.47	2680	164.7	2130	2000	2.87	0.899	0.875
	3.27	3000	181.2	2120	2130	3.67	0.86	0.852
	4.07	3280	178.2	2140	2120	4.49	0.844	0.844
	4.98	3600	178.2	2160	2110	5.38	0.852	0.844
	5.89	3920	183.5	2150	2130	6.39	0.86	0.844
	6.9	4280	180.5	2170	2170	7.3	0.828	0.836
	7.7	4560	182.7	2170	2160	8.1	0.821	0.836
	8.5	4800	175.9	2150	2140	8.9	0.836	0.836
	9.3	5080	175.2	2170	2160	9.72	0.821	0.836
	10.21	5320	185	2230	2180	10.61	0.828	0.836
	11.03	5600	187.2	2270	2220	11.41	0.828	0.836
	11.83	5800	174.4	2270	2200	12.23	0.828	0.836
	12.63	6000	177.4	2240	2130	13.04	0.813	0.836
	13.44	6160	180.5	2190	2120	13.94	0.836	0.836
	14.34	6360	169.2	2130	2070	14.76	0.828	0.836
	15.25	6520	162.4	2060	2130	15.64	0.821	0.836
	16.05	6680	153.4	1990	2180	16.45	0.813	0.836
Code:
Sunday	15	November	2009	06:32:12
	TIME					TIME					TIME
	0	1760	21	0	1000	0.43	0.2	-8.6
	0.83	1920	21	95.3	1100	1.32	0.2	-8.6
	1.74	2120	20	95.3	1320	2.14	0.2	-8.6
	2.54	2360	18	95.3	1590	2.94	0.2	-8.6
	3.34	2640	18	85.1	2000	3.74	0.2	-8.6
	4.15	3000	18	76.9	2130	4.55	0.2	-8.6
	4.95	3320	18	78	2140	5.35	0.2	-8.6
	5.75	3680	18	78.8	2160	6.15	0.2	-7.8
	6.57	4000	18	79.2	2160	6.97	0.2	-7.8
	7.47	4400	20	79.6	2170	7.87	0.2	-7.8
	8.27	4720	21	81.2	2110	8.68	0.2	-7.8
	9.18	5080	22	83.9	2120	9.58	0.2	-7.8
	9.98	5360	24	88.2	2200	10.38	0.2	-7.8
	10.79	5640	25	95.3	2180	11.29	0.2	-7.8
	11.71	5920	27	95.3	2150	12.2	0.2	-7.8
	12.6	6200	30	95.3	2160	13	0.2	-7.8
	13.51	6440	32	93.7	2160	13.91	0.2	-7.8
	14.31	6600	33	83.5	2240	14.71	0.2	-7.8
	15.13	6760	34	74.9	2000	15.62	0.2	-7.8
The previous set up shows a maximum mass flow of 194.17g/s,
The Jetex set up shows a maximum mass flow of 202g/s, a gain of 7.83g/s and if I'm correct
a potential power gain of just over 10 BHP.
I'm still getting to grips with Vag-Com so any comments or help is appreciated.
I'm afraid I'm still with the tie wrap jobbie as pictured in post 92, lol. I want to put a bit of an
extention in before I fit something permanent but it's fine for now.
(Where would British Industry be if all the tie wraps, welding rods and bits of tape all broke at the same time??)
:D
Yeah that's what i've been thinking for mine. Probably only need a bit of silicone pipe, about 2-3 inches long, should put it right next to the wing. Is there anywhere suitable to attach a support near the wing? Can't say i've looked since i bought mine
