no they don't. mk4 PCD is 5x100.
BMW is usually 5x120 i think. not even worth trying mate
Yea BMW is 5x120... you could try hub adaptors but be careful with the offset, you'll need around an ET35-40. So if the wheels are off a 5 or 7 seiries they won't fit. Most 3 series fitments would be about an ET40.
thanks for reply bt ive been offered merc amg wheel 18'' would they fit.
Mercs are 5x112 you'd need hub adapters again... I think the offset on those would be about right... normally a 32-35 I think :S the Mk1v should be ok on 18's the guys back at work would know a bit more than me though.
^^ Erm... What Mk4 CupraR?
PCD
Just Remember The PCD (Pitch Circle Diameter) is the arrangement of the studs/bolt pattern on the hub:
So as said you'll need 5(studs) x 100mm diameter (how far the studs are from the centre of the hub)
If the wheel has a different PCD you can buy an adapter kit (which will also act as a spacer)
Offset (ET)
Now the Offset for the standard wheels are ET37 IIRC?? but it's usually acceptable to got 5-7mm either way of this (depending on width)
If you Reduce the Offset (Say ET37-ET30) you are moving the wheel 7mm further towards the wheel arch of the car and can get rubbing etc
Conversely if you go (Say ET37 - ET40) then you are moving the wheel 3mm further into the wheel arch and can risk fouling the suspension strut/brake caliper (to counter this you can use spacers)
If you get wider wheels, ie moving from a 7J to 8J (7" - J is a denomination of the Wheel profile and determines what type of tyre it can take) you may need to alter the offset to move it further out/in from the hub depending if it's a deep dish (and may foul the arch) or not so deep and foul the strut... but that depends
Spigot diameter
Another thing to consider is the spigot diameter - if the spigot size is larger than your current spigot size then you will need a spigot ring tio stop all the stress being placed on your wheel studs (which can shear if this is the case!)
what kind a money is it for wheel adapters and where would u get them or are u better goin 4 a smaller size with the right size hub bolts.
I'm not sure on the pricing but maybe £150 for a kit? I'd try to stick with the right PCD if you can! The only reason to really use adaptors is if your dream wheel isnt made in the right PCD imo
i see think al try n stay with the correct PCD then thanks for the advice.
they were m3 wheels ma pal was selln me them 4 cheap cheap so a wanted some advice b4 i bought them lol.
What you've quoted hasn't got anything to do with the wheel (dirtectly anyway) it's the specification for the tyre:
205 - Width of tyre in mm
50 - Tyre profile (aspect ratio of tyre width to tyre wall height)
R - Radial type construction
86 - This has something to do with loading I think
V - This is the speed rating (V= up to 149mph)
