brakes
here is a few pics of things that have arrived and av collected in the last month.
things for the front brakes, retaining pins and springs, DS2500 brake pads, Tarox G88 312mm
retaining pins and springs dont no if there right, its what the my local dealer got me am not sure if there right because they couldn't even get me the right mats when i 1st got my car.
things for the back brakes, Pagid pads and Tarox G88 232mm
size difference
hopely i'll get them fitted in the next couple of weeks.
custom splitter
i had a splitter for a while and didn't get round to fitting it, then i seen Altechs custom splitter which made me want to try to make 1 myself, here is the results.
original splitter.
to get the right shape i made a template of the bumper.
i cut 1 of the splitters in half the heated the sides with the heat gun to get them bent to the right shape.
next i cut the lower middle bit out of the other splitter and plastic weld the joints.
i filled the joints with body filler and then sanded the whole bumper down then wet and dry for a smooth finish.
then i was ready for painting. after painting i drove on to the template to give me a little more room to fit the splitter. so here is it fitted.
thats well nice and different only thing it looks really low your car, not a pain if you hit it/?? would it not break easy??if not a***** job
It looks really good mate :)
I think the way you've done it in 3 pieces follows the bumper lines better than mine.
Have you strengthened it underneath? I plastic welded a long strip of 5mm plastic underneath mine to avoid the main join cracking if I scrapped it.
cheers, i got the idea for it off altech, it only looks that low because of the driveway is on a slope and flattens off at the bottom. its just lower that a kerb height on the flat so hopely wont hit anything.
am glad you like since it was yours the gave me the idea
yeah i plastic welded strengtheners under each joint, i just used the off cuts from the waste bits of splitters.
gave my car a quick clean this morning before it started raining again.
it needed it, 4 or 5 weeks since it was last done.
before
halfway i give it a quick wash off to see how bad it was.
and finished just as the rain started
quick update,
the good news
ordered few things yesterday little xmas present for myself,
kw v1 coilovers
whiteline RARB
20mm spacers
i wont get them to new year but i cant wait.
the bad news went for a drive last in the snow, slid into a kerb straight on and broke my splitter. its broke on the joint so will hav to take it off and reweld. gutted.
quick update,
the good news
kw v1 coilovers
whiteline RARB
20mm spacers
Nice mods mate. Bummer about the splitter though...
