Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Hi just fitted some 6x9 in other day, wanted to ask do you need to run the speakers in or just crank the volume straight away? The speakers are vibes 400watts 135rms powered 600 watts fusion amp. :whistle:
Turn it to 11, make sure they dont blow and away you go!!! Normally the only issue with speakers are they dont fit 100% so they rattle a bit.
11?!is that a standard level to turn all car radios to?lol.
Its the same as any speaker just for the first hour let the cone stretch a bit before turning it up a bit.I wouldnt be too concerned though,should be something you do with a sub more than anything else as the movement they do is far bigger than any other speaker
matt
