It was really cold today and the car was iced up (the temp displayed -1.5) so I ran it for about 10 mins to warm up before turning it off to go inside.
When I came out 5 min later and turned on the ignition the air/con heater display showed every numeral on the lcd screen! It then began to flash with a full lcd display then blank etc.
I turned the ignition off and back on again a few times and the same thing happened. Getting slightly worried I started the car and the display turned back to normal except the temperature display now read 9.0c ?
I drove the car a few miles and the temp slowly fell to around 2.5 c which is about right.
The display now seems fine when turning on and the temp has returned to normal its wierd.
Has anyone had this full lcd display flashing before?
