Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
the sidelights are replaced through a seperate cover to the side of the main cover, on the wing side of the headlight.
It`s the triangular cover on the right side of my pic (driver`s side headlight):
Move the metal clip out of the way and the cover hinges on the two plastic lugs, then comes out completely. Two wires go into the sidelight but as said don`t pull on them... Grip the sidelight with your finger and thumb and pull hard with a bit of a wiggle
When fitting, i found it best to switch the sidelights on to help you locate them properly.
Thanks I Got 1 Side Out But The Other Wont Budge Ive Tried Everything But A Sledge Hammer Wich Iam Close To Using! Is There Any Technique Or Is It a Case Of Just Pulling The Holder As Hard As You Can!
Its As If Theres Something Clamping IT Into Position But I Cant See Anything The Drivers Side Came Out When I Pulled Off The 2 Wires I Thought I Snapped Something To Be Honest But This Side Is Murder!
Thanks Buddy Al Give It A Go Al Let YOu Know How I Get On Your Car Is Minted A Just Had a Wee Look There!
I put LED bulbs in to mine - it kept blowing standard bulbs - the LED's have been in two years now and never failed.
have a look for 501 or w5w led bulbs.
