_chris_
349
in the car
Need a bit of help for my mate,
he has just brought a ibiza cupra with revo stage 2 and it has got some sort of water injection on it.
he wants to remove it because we dont know if it been set up correctly, i believe the timing has bee advanced just over 5 degrees, what is the best/easiest way of putting the timing back to normal, to suit the car without the water injection?
im not sure but i believe we may be able to do it with
- vag com/ lemmiwinks?
- revo select switch thingy?
any help would be much appretiated,
i think fourtwofive i think thats his username recently stripped out an aquamist system from his might be worth a pm
pull instrument fuse, use unisettings, read ecu, look at ign setting, and if its anything >0 then you reset it to 0, write back to ecu
refit fuse
job done
